Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-27-2009, 03:45 PM   #1
Trim caulking near corner of room
Hi All,
I am presently in the process of caulking the edges of all the casing trim in the house, which I have recently installed. My question is this... on some of the doors, the trim is very close to the corner of the room, I would say between 1/8 and 3/8 of an inch from the corner. Would it be better to caulk this gap all the way to the wall, then paint the caulk the same color as the trim, or try to do just a thin bead and then get a tiny line of paint between the trim and the wall.
Thanks!
RxScram is offline   Reply With Quote
Old 09-27-2009, 04:11 PM   #2
Remodeler
MinConst's Avatar
If these are interior doors your talking about I wouldn't worry about caulking this section. You can't see it can you? When you paint the wall just paint the wall with a small brush in there and paint the trim just around the edge so as not to get trim paint on the wall.
If these are exterior doors you should have a seal before the trim goes on so the same holds true as with above. An air seal is made with foam, or insulation on an exterior door.
Don't fill the whole area with caulk.
These areas are a pain in the neck :-)
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-27-2009, 08:18 PM   #3
In my recent remodel I had two doors near the same corner - I had to even use a narrower casing so they did not touch one another. There is no caulking there, no way, and I had a heck of a time with the painting. But one can't see the problem areas, so it really matters not.
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
caulking trim before painting ponch37300 Painting 10 05-15-2009 11:16 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
one corner of secornd floor room is low 99th_Flyby General Discussion 9 01-12-2009 09:25 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
