Trim Around Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 12:34 AM   #1
Trim Around Window
My fiance has a house that is fairly new, but the trim around the window in the bathroom is starting to fall apart. It's particle board and I don't think it was weather treated. I'm going to replace the trim this week with weather treated 2x4's, is there anything else I need to do? It's just the trim that's messed up, and it has to be done before they will approve a loan and finalize everything. I appreciate everyone's help, and look forward to getting a lot if input and work done.
Mark
markandchristy is offline   Reply With Quote
Old 03-28-2009, 04:44 AM   #2
the Musigician
DangerMouse's Avatar
outside trim? particle board? hmm... i never use that stuff for anything, let alone outdoors or inside in a wet location.
i had the same situation here, before they'd do the loan, they wanted me to put soffit in an area where none was needed. no ventilation there!
kinda stupid, but i had to do it.
DM
Old 03-28-2009, 06:22 AM   #3
If you are talking about exterior brick molding, there is a vinyl or composite version available, that will not rot. Use that as a replacement. There are also some versions of interior trim that stand up better for bathroom trim.
Old 05-09-2009, 01:04 AM   #4
Pic of rotting wood, it was pretty much like this all the way around the window.
After taking the old trim off and putting up new trim and sealing it off.
Completed Job, sealed, painted, the works.
sorry it took so long to get these up.
Old 05-10-2009, 12:56 PM   #5
Rewards Points: 5,336
That is a very odd wood configuration on a brick house. Looks like some previous homeowner's way of getting larger windows in without the expense of a mason.
From the pictures it looked like T-111 siding with wood trim, maybe some MDF.
Properly repaired, you should be good for a while.
Ron
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
How to trim window ryan16 Carpentry 9 02-27-2009 09:56 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 08:49 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
