Trim Around Door, But Desk In The Way - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-06-2016, 03:31 PM   #1
Rewards Points: 398
Trim around door, but desk in the way
Hello, Not sure if this is the right section, but I'm looking into replacing all my base trim and adding molding around the entrance ways. The one entrance to my dining room has a kitchen desk which has granite sticking out. How would you add molding around this?
If it helps any, the existing granite backsplash will be removed in lieu of a tile backsplash in the near future.
Trim around door, but desk in the way-image-1757809469.jpg   Trim around door, but desk in the way-image-2185218321.jpg   Trim around door, but desk in the way-image-1079931820.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 03-06-2016, 08:42 PM   #2
Rewards Points: 13,228
Guess I'm missing something.
Base would be ran up to the plywood leg and ended on each side.
No way would I replace that granite with a tile back splash.
Just going to cheapen the look.
Back splash and to should have been caulked to finish that gap.
ddawg16 (03-08-2016)
Old 03-06-2016, 08:59 PM   #3
Rewards Points: 398
Sorry if I'm being unclear -
I want to add molding up and around the entrance to the dining room. Molding will fit around the whole entrance except where the granite sticks out on the right side of the entrance. I was looking for any possible solutions.
Old 03-06-2016, 09:51 PM   #4
DIY staff
Rewards Points: 7,174
We call that a 'cased opening'----
The casing will need to be coped around the desk---some careful measuring and then remove the waste wood---caulk and done.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
BigJim (03-06-2016), ddawg16 (03-08-2016), de-nagorg (03-06-2016)
Old 03-06-2016, 09:52 PM   #5
DIY staff
I moved this to 'carpentry ' for you.
Old 03-07-2016, 11:40 AM   #6
Rewards Points: 242
I have a similar situation in my kitchen. I just put in a new countertop. The contractor did what was mentioned above. They used a coping saw to cut the moulding so it wraps around the countertop. They did a pretty crappy job. I really don't like the way it looks, but I don't think there was any other option.
If you're going to do it, make sure you take your time and make it fit correctly.
b-boy is offline   Reply With Quote
The Following User Says Thank You to b-boy For This Useful Post:
oh'mike (03-07-2016)
Old 03-07-2016, 10:53 PM   #7
firehawkmph's Avatar
Rewards Points: 1,822
How wide is the casing you're planning on using? By the time you get your jambs in place, you should have about 3" to work with before you touch the granit countertop. If it does hit, it's easy enough to mark that piece of casing while holding it in place and then notching it with a hand coping saw.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
adgjqetuo (03-08-2016)
Old 03-08-2016, 12:51 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Yep....leave the granite backsplash....and just cope the case around the granite....or use a more narrow case molding.
Old 03-08-2016, 08:07 AM   #9
Rewards Points: 803
on trim interference issues, I always modify the piece that is most likely to be replaced before the other.
however, the difficulty to modify granite may be a game changer.
next best bet is to use narrower trim there to not interfere.
TimPa is offline   Reply With Quote
Old 03-08-2016, 08:14 AM   #10
Rewards Points: 398
Originally Posted by firehawkmph
How wide is the casing you're planning on using? By the time you get your jambs in place, you should have about 3" to work with before you touch the granit countertop. If it does hit, it's easy enough to mark that piece of casing while holding it in place and then notching it with a hand coping saw. Mike Hawkins
That's a really good point - I didn't account for the thickness of the jambs. This may add just enough space - I'll have to re-measure it later.
Why is everyone against removing the small piece of granite behind the desk counter? It's in our kitchen and I was planning on removing all of the back pieces on the regular counters as well and put in a tile backsplash. Something like this I was thinking of.
Old 03-09-2016, 08:38 AM   #11
Rewards Points: 492
With a grinder/diamond blade, notching the stone would be my choice. Notched wood trim always looks bad, and that is what the eyes would notice.
If you cut the trim, drill a hole first and that will get you very clean circle.
carpdad is offline   Reply With Quote
Old 03-09-2016, 09:35 AM   #12
I don't have a problem with removing the granite backsplash and replacing it with tile. I don't like granite backsplashes because they normally cut them from the same thickness material as the top, and they look way too thick for me. I prefer tile for a backsplash and have done many that way.
Mike Hawkins
Old 03-10-2016, 07:39 PM   #13
Rewards Points: 398
So it looks like with the jambs installed the molding should be able to fit without trimming around the granite. Trying to evaluate other areas too though - how would this section work with the door molding so close?
Won't it look out of place with 2 pieces of molding and a skinny strip of drywall in between?
Old 03-10-2016, 08:14 PM   #14
Rewards Points: 398
Here are a couple more pics of the entrance way if it helps any.
I'm assuming looking out toward the front I would go all the way around, but looking into the family room just across the top right? What about the square upstairs landing area just above the entrance way?
Trim around door, but desk in the way-image-1786459863.jpg   Trim around door, but desk in the way-image-3653383998.jpg
Old 03-11-2016, 07:24 AM   #15
Rewards Points: 803
personally, I wouldn't trim wall openings. just doorways and windows.
Question about hardiepanel/T-111 and window trim Alan Roofing/Siding 4 08-22-2014 10:06 PM
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 02:52 AM
Replacing Small Sections of Rotted Trim FrazzledMom Carpentry 2 07-07-2014 07:15 PM
Old Flooring and Trim Identification and Refinishing BungalowBaby Flooring 8 07-02-2011 07:17 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
