Trim Around Countertop - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 08:06 AM   #1
Smile
trim around countertop
What choices are there for trim around a curved countertop that is unfinished on the edges? The thinnest the better. Is flextrim my best choice or formica or what other choices are there?
sgtrock is offline   Reply With Quote
Old 01-26-2010, 08:45 AM   #2
Remodeling Contractor
If this is a formica countertop then use formica. (Thinner grade stock is available for curved edges or heat and clamp as you go) Or use a wood edge that is laminated to fit the curves.
Old 01-26-2010, 08:53 AM   #3
This is a 12" x 12" granite countertop
Old 01-26-2010, 09:15 AM   #4
Too Short? Cut it Again!
You may have trouble getting much to stick to an unfinished granite edge. The material is porous and may just suck in the adhesive. How do you come to have a curved granite countertop that did not have the edges shaped and finished in the process?
Old 01-26-2010, 09:20 AM   #5
DIY project. There is about 1x1/2 inches of plywood to fasten trim to plus the cement board, mortar and granite for a total of 2x1/2 wide I need the trim to be. On the regular straight edge countertops I did this the same way and wood trim screwed on and painted white looks great.
Old 01-26-2010, 09:27 AM   #6
just laminate the wood from thin strips of wood glued together and formed to the shape you need. this way it matches the rest. And anything will glue to the granite fine. Normally we use silicone for this.
Old 01-26-2010, 09:32 AM   #7
Gotcha. I think. So you glued and nailed the other trim on?
Well I would use whatever you used elsewhere to match then. You may have to steam the trim to make it bend around the radius. You can make yourself a quick and dirty steamer out of PVC drain pipe. Cap one end completely. Modify the other end to accept the tubing from whatever Rube Goldberg steam source you come up with. Be patient and don't race the steaming process or you will snap the trim trying to bend it.
Old 01-26-2010, 09:41 AM   #8
if you have enough room/overhang trace the radius onto a piece of ply then create a negative form with small blocks to your radius line. glue/ laminate thin strips to radius and clamp, or you can steam larger as said previous.With the lamination of flat stock you can then use a router for any profile
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
