Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-27-2009, 03:29 PM   #1
Trim around a Brick fireplace
I need ideas for trimming around a red brick ceiling to floor fireplace. The other trim in the room is natural wood color. We think it would look nice trimmed out in a painted cream colored wood trim but not sure it would go with the other trim in the room which is on the windows and floor, no crown molding in this room. The mantle is made of bluestone.
DBarton is offline   Reply With Quote
Old 02-27-2009, 04:57 PM   #2
Building codes guy, Mod
thekctermite's Avatar
Just be sure to maintain the minimum required clearances from the firebox opening to wood. Oversimplified, if you keep the wood 12" away from the opening you've met the code requirement.
As for the appearance, you should post a picture. Once people can visualize the fireplace you'll get all sorts of ideas.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 02-27-2009, 05:45 PM   #3
Chicago, IL
Michael Thomas's Avatar
For starters, there are some clearance requirements when placing a combustible mantle above a fireplace:
Fireplace Mantel Clearances
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Last edited by Michael Thomas; 02-27-2009 at 05:54 PM. Reason: Deleted - Link no longer works
Michael Thomas is offline   Reply With Quote
More On This Topic
Hi, I'm Betty Ingham and I'm speaking on behalf of Expert Village. When we moved into this house over 8 years ago someone had just put concrete in the bottom of this fireplace. The mantle was painted many, many colors and so once we stripped out all the... Read More »
Many outdoor fireplaces are fancier than indoor ones. Some expensive fireplaces stand over eight feet tall and include MP3 docks. Less fancy ones are just a metal bowl with legs. Almost anyone can afford an outdoor fireplace because there are many styles... Read More »
Learn how to collect antique mantle clocks and shelf clocks, in this free collectibles video guide. Read More »
A fireplace is easy to make a focal point. Since most fireplaces are already in the central part of the room, and are large in size, it is only necessary to accentuate it. With all the accessories and options available to enhance fireplaces, it is easy... Read More »
Cheap is chic. Flea markets (or swap meets or lawn sales) are an untapped decorating gold mine. Find whimsical decorative accents for every room in your house to create a fun and funky flea market style. Use your imagination and turn everyday objects... Read More »
Refacing a brick fireplace Cork Grones Building & Construction 2 11-10-2008 07:47 AM
Putting Tile over brick fireplace? sammyjk1 General Discussion 1 02-25-2008 04:47 AM
Family Room Color / Giant Brick Fireplace kashimama Interior Decorating 3 12-25-2007 03:42 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
