Trim Around Baseboard Radiators? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 12:04 PM   #1
Rewards Points: 165
Trim around baseboard radiators?
I recently renovated my living room and dining room and I am at the stage where I am installing the baseboard trim. My only issue with this is that my house has several cast iron baseboard radiators and several cast iron convenctors. The baseboard radiators are only about 8 inches tall and 6 to 8 feet long and sit against the drywall. The cast iron convectors are about 2 feet tall and 3.5 feet long and are recessed into the 2x4 walls. This leaves apporximately 2 inches sticking out past the drywall. I have chosen a baseboard trim that is 5.25 inches tall and I don't know if I should use it to trim around both the radiators and convectors. I think it would look weird running up the sides and tops of the radiators and convectors. But I also think it would look weird to use my door and window casing. What should I do?
chronojosh is online now   Reply With Quote
Old 12-20-2011, 05:37 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
On the large one that sticks out from the wall, I would just but the baseboard up tight to. Perhaps you ca do that both. You didn't mention if the smaller one sticks out. You could also bring the baseboard into the radiator and do returned ends on it. I definitely wouldn't run the baseboard around it.
Millertyme is offline   Reply With Quote
Old 12-27-2011, 02:04 PM   #3
Retired carpenter
Have the baseboards butt against the radiators, and don't trim around them (it will look awful). Just use drywall mud around them (fix-it-all first if you have big gaps).
abracaboom is offline   Reply With Quote
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 09:39 AM
Measuring trim for mitered baseboard installation abbyqueue Carpentry 3 07-28-2009 01:54 PM
Baseboard trim height from floor billyg Carpentry 6 01-20-2009 11:08 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 01:31 PM
