Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 11:33 AM   #1
trim
whats the best way to cut base board trim in the corners to have them meet perfect at a 45 angle
crzyd247 is offline   Reply With Quote
Old 08-02-2008, 01:36 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
outside corners should be cut on a 45, inside corners coped. run one side tight to wall cut the next piece at a 45 degree with the face on the short side and the back on the long side. then follow the out line with your coping saw. 45 degree inside corners are box store approach. all inside corners should be done with a coping saw, this way your miters will not open and will stay tight. BOB.
Old 08-02-2008, 01:47 PM   #3
Contractor - Renovations
fungku's Avatar
what he said.
and you can use rasps to fine tune your copes for a perfect fit.
fungku is offline   Reply With Quote
Old 08-02-2008, 02:24 PM   #4
Registered User
Termite's Avatar
No offense if I'm over-simplifying, but a miter saw is used to make these cuts. Bob's definately right about coping inside corners. It is a must for a professional-looking job. Inside corners of base shoe should be coped as well.
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 04:42 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 12:31 PM
