Tricky Door Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 05:25 PM   #1
Question
tricky door trim
i have 3 doors that are in a hallway, i have changed the moldings and now on one side of 2 of the doors the trim has to be cut "into" each other because they touch, one door is slightly lower and i can not figure out how to miter the cut, should the TOPS of the trim be even, if so there will be a gap on middle door, any suggestion?
deeva765 is offline   Reply With Quote
Old 02-22-2011, 05:26 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
A picture of the trim will be necessary and very helpful
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
deeva765 (02-22-2011)
Old 02-24-2011, 03:07 AM   #3
can't figure out what you're talking about, a pic would be good
chrisBC is offline   Reply With Quote
tricky drilling yanni286 Building & Construction 6 04-28-2010 07:28 AM
Tricky Backsplash installation katliz Building & Construction 2 03-29-2009 04:49 PM
Half way laid done and now come to a tricky part KUIPORNG Landscaping & Lawn Care 4 07-14-2008 11:15 AM
Installing Hardwood in Tricky SpotHi, georgemichael Flooring 1 11-20-2006 11:47 PM
