Triangular Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-14-2014, 10:48 PM   #1
Rewards Points: 12
Triangular Window
Is it possible to cut crown molding along the long side of the attached window (crown goes to the ceiling), then miter another crown molding piece on the vertical side? Horizontal run would be a ledge. Much appreciated!
gary5555 is offline   Reply With Quote
Old 01-14-2014, 10:55 PM   #2
Rewards Points: 12,794
Not a great Idea to even attempt it.
If you have to have crown, end it in that bottom right hand 45 deg. corner.
Old 01-14-2014, 11:13 PM   #3
Rewards Points: 12
Do you mean: only have the crown on the top, angle piece (hypotenous), and not on the other 2 corners (forming the right angle)? What other trim pieces, other than the casing, do you suggest?
Old 01-14-2014, 11:32 PM   #4
Do not run any crown anywhere near that window.
Just along the wall to the right of the picture, or no crown. at all
Old 01-15-2014, 06:53 AM   #5
DIY staff
Rewards Points: 7,174
One good method of installing crown above a window that is to close to the ceiling --retrim the window--use a flat header board on the top of the window---and casing on the other sides--then strep out the crown molding when it reaches the header board----
That treatment looks good on a standard window--I think it will look good on that triangle,too.
Trim is cheap---do an experiment and see if you like it.
Old 01-15-2014, 06:54 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
on a window such as that i wouldnt consider it unless you plan on building up the trim.. via running some flat stock all the way along the wall to ceiling junction.. other wise your in for a real nightmare of a time trying to make those compound cuts at the window to return the crown into the wall
woodworkbykirk is offline   Reply With Quote
Old 01-15-2014, 10:41 PM   #7
AHH, SPANS!!!
Rewards Points: 1,166
Hi, I will post instructions in the morning. are serious about doing this? asking because of how much detail to provide...
hand drive is offline   Reply With Quote
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
