Triangle Molding Under Staircase - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 07:56 PM   #1
Triangle molding under staircase
I am having difficulty figuring out angles for molding under staircase. Bottom left angles is 90, any tips on how to measure the other two?
mriup94 is offline   Reply With Quote
Old 08-01-2012, 09:26 PM   #2
DIY staff
Rewards Points: 7,174
Do you have an adjustable angle?
Old 08-01-2012, 09:33 PM   #3
DIY staff
Use this tool--to find the angle---a cheap plastic one will only cost $5.00 OR LESS--
Once the tool is set to the actual angle--use that to cut or fold a sheet of paper to match--fold the paper in half at the point--That is the miter saw angle---make a test block--adjust for a perfect fit--then use those numbers--
Or buy a protractor---every one has paper on hand---Mike---
Old 08-01-2012, 09:33 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
If I'm not mistaken, that base cap cut is About a 72 degree cut 2 times on the right bottom point . About a 63 degree cut 2 times on the left upper point. If you are adding a flat section at the top left point then that will be a different angle. Your two angles you're working with will probably be About 36 degrees and 54 degrees respectively.
Those angle finders are fun! A line on the wall and a speed square with a torpedo level is a quick and easy approach too, if you can swing the speed square around without bumping into something
hand drive is offline   Reply With Quote
Old 08-03-2012, 05:18 PM   #5
Thanks for the tips, going to give it a shot tomorrow
Old 08-04-2012, 10:30 AM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
Hand drive is right. My guess would have been 75degree angles. Of coarse now you will need to make a quick jig to cut them accurately on the chop saw. I usually cut a piece of 1x4 to a 45 degree angle and use the pitch cut as my fence. You can cut very steep angles this way. Hold on to that work piece though.
Millertyme is offline   Reply With Quote
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 06:38 AM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 02:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
