-   -   Triangle molding under staircase (http://www.diychatroom.com/f14/triangle-molding-under-staircase-152261/)
mriup94 08-01-2012 08:56 PM
1 Attachment(s)
I am having difficulty figuring out angles for molding under staircase. Bottom left angles is 90, any tips on how to measure the other two?
oh'mike 08-01-2012 10:26 PM
Do you have an adjustable angle?
oh'mike 08-01-2012 10:33 PM
http://www.woodville.co.nz/images/dcp00272.jpg
Use this tool--to find the angle---a cheap plastic one will only cost $5.00 OR LESS--
Once the tool is set to the actual angle--use that to cut or fold a sheet of paper to match--fold the paper in half at the point--That is the miter saw angle---make a test block--adjust for a perfect fit--then use those numbers--
Or buy a protractor---every one has paper on hand---Mike---
hand drive 08-01-2012 10:33 PM
If I'm not mistaken, that base cap cut is About a 72 degree cut 2 times on the right bottom point . About a 63 degree cut 2 times on the left upper point. If you are adding a flat section at the top left point then that will be a different angle. Your two angles you're working with will probably be About 36 degrees and 54 degrees respectively.
Those angle finders are fun! A line on the wall and a speed square with a torpedo level is a quick and easy approach too, if you can swing the speed square around without bumping into something :)
mriup94 08-03-2012 06:18 PM
Thanks for the tips, going to give it a shot tomorrow
Millertyme 08-04-2012 11:30 AM
Hand drive is right. My guess would have been 75degree angles. Of coarse now you will need to make a quick jig to cut them accurately on the chop saw. I usually cut a piece of 1x4 to a 45 degree angle and use the pitch cut as my fence. You can cut very steep angles this way. Hold on to that work piece though.
