Treated Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 07:28 PM   #1
treated wood
can you glue treated wood if it is still a little wet?
slim666 is offline   Reply With Quote
Old 05-17-2011, 06:01 AM   #2
depends on the glue. Most glues will not work when damp, but urethane glue(Gorilla Glue) works better when damp, requires moisture to cure. Parts must be tightly clamped.
Old 05-17-2011, 07:43 AM   #3
Rewards Points: 5,336
What are you making?
Ron
Old 05-18-2011, 06:14 PM   #4
treated wood glue it
Ron
I made a nice fence get glued the 2 bys & used pocket hole kreg jig the wood was still a little wet i used gorilla white glue. thank you slim
looks like its ok
Old 05-18-2011, 08:25 PM   #5
looks like its ok
I have no idea what you just said. Is there a 62 year old translalation available?
Ron
Painting Pressure Treated Wood stephen44 Painting 14 05-14-2016 08:22 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 03:04 PM
HELP! I did not use treated wood. Any solutions? Smith305 Remodeling 8 04-03-2010 04:48 PM
Pressure/CCA/Arsenic treated wood sparklesarah144 Building & Construction 4 03-12-2010 10:49 PM
