Treated Lumber - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 12:44 AM   #1
treated lumber
how long does treated lumber need to dry before painting?
first flight is offline   Reply With Quote
Old 06-21-2011, 06:34 AM   #2
Often, when you get PT lumber, it is litterally dripping wet, sometimes it is nice and dry to the touch. Rule of thumb is to let it air dry about 6 mo.
But i would never paint PT wood, it expands/contracts too much to hold paint. Solid stains would work much better.
Old 06-21-2011, 06:41 AM   #3
Too Short? Cut it Again!
And PT wood can be wet on two fronts. It can be wet from the treatment and from the fact the wood itself went directly into the treatment tank process without any natural or kiln drawing time.
I agree solid color stain would be a better choice than paint. I would add, that if you can find a color that blends all together to your liking, a semi-transparent stain would be even better.
And yes, wait at least 6-years if you can although many PT manufacturers claim you can apply finishes immediately.
Old 06-21-2011, 04:38 PM   #4
Gymschu's Avatar
Rewards Points: 662
Good advice........I have gambled a few times with painting PT wood & it worked out. Other times, not so good. The moisture content of the wood (even after 6 months) will push the paint right off. Indeed, stain is your best option........
Old 06-21-2011, 04:58 PM   #5
Oops was not watching what I was typing. Thanks for correcting to six months.
Old 06-23-2011, 05:50 PM   #6
I had read somewhere, before applying a finish to PT wood, to put a teaspoon of water on the wood, if it doesn't soak in,in a very short time, its not ready for the finish,, sorry I can't define "short time", I've forgotton the time span since reading the article.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Treated lumber secutanudu Painting 5 09-11-2010 11:51 AM
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 09:49 PM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 12:08 PM
Galvanized Flashing with ACQ Treated Lumber? Ler0y Jenkins General DIY Discussions 5 05-18-2008 10:59 AM
