Treads And Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-24-2009, 01:49 PM   #1
Treads and wall
I have 2 sets of staircases where the tread doesn't meet the wall. There is anything from a 1/16"-1/8" gap between them. Would should I put to hide the imperfections? Moulding? Any ideas/pictures would be greatly appreciated.
http://picasaweb.google.com/jared515...eat=directlink
Thanks,
Jared
jared515 is offline   Reply With Quote
Old 04-24-2009, 10:09 PM   #2
Registered User
Rewards Points: 526
If you have access under the stairs, I would molly the sheetrock to the treads. Be safe, G
Old 04-25-2009, 06:29 AM   #3
Rewards Points: 5,336
How do you molly a vertical surface to a horizontal surface?
That aside, there isn't too much you can do unless you want to skim coat the wall to cover the gap. Or you could replace the treads, but that would be extreme.
Caulking the space would be the easiest.
Ron
Old 04-25-2009, 01:16 PM   #4
Registered User
Rewards Points: 526
If accessible, drill through the stringer, and the rock. Insert molly, tighten, it pulls the rock to the stringer. Done that a few times. Works on cabinets, too. Obviously limited, depends on where the studs are. Be safe, G
Old 04-25-2009, 01:35 PM   #5
Thanks for the ideas. I will see if I have access to the sheetrock, but I don't think I do.
Old 04-25-2009, 01:38 PM   #6
[quote=GBAR in WA;265403]If accessible, drill through the stringer, and the rock. Insert molly, tighten, it pulls the rock to the stringer. Done that a few times. Works on cabinets, too. Obviously limited, depends on where Thanks, G. Appreciate the insight.
Another option I thought of was a skirt board. There was a thread a week or so ago that had a good way of making one.
Ron
Old 04-25-2009, 02:22 PM   #7
Carpenter
[quote=Ron6519;265410]
Ron
here you go Stairway skirt board template - easy
Bucky Badger is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
How do I install trim around stair treads? JayBird Carpentry 22 08-07-2010 04:16 PM
Replace old treads with Oak treads ruler10 Carpentry 19 07-21-2010 09:55 AM
Progress with Nw Barn Staircase! wombosi Project Showcase 2 03-03-2009 03:59 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
