Treaded 2x4 On All Walls Or Just Exterior Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 02:26 PM   #1
treaded 2x4 on all walls or just exterior walls
do i need to use pressure treaded 2x4s on all my walls in the basement or just the exterior walls
thx
ron0805 is offline   Reply With Quote
Old 10-07-2009, 03:48 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Use pressure treated where the studs, sills, etc. are in contact with concrete that is in contact with the soil. You can use an appropriate barrier between the wood and concrete and eliminate the nasty pressure treated wood. Whenever you nail into pressure treated wood, use the appropriate type nails to prevent them from being eaten up.
Just because it is concrete does not mean it must be pressure treated wood.
Dick
concretemasonry is online now   Reply With Quote
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
