Tread & Riser Problem Please Help - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 09:52 PM   #16
So there you go Robert, your choices depend on whether or not you can remove the stringers and drop them down or have to adjust them in place. If you can detach them and move them down, then just trim 1/4" off the bottom of the stringers, lower them and refasten. If you have to adjust them in place, then you'll either have to trim 1/4" off the top off every step, and have equal risers top to bottom, or finagle them, as suggested by Allan, and trim only the first and last step and live with the variation in the first and last steps.
dave54 is offline   Reply With Quote
Old 12-18-2011, 09:56 PM   #17
Msradell's Avatar
Rewards Points: 128
I was actually just thinking about this problem and came up with another solution. You could use a router and make ¼" deep pockets on the bottom of the treads! That we would have to do anything to the stringers.
Msradell is offline   Reply With Quote
Old 12-18-2011, 10:31 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
If you do that don't route all the way through the nosing as it will show. Also you will need to make sure your riser is dropped 1/4 inch at the top to allow for the tread being lowered.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-18-2011, 11:30 PM   #19
Old School
Willie T's Avatar
I was actually just thinking about this problem and came up with another solution. You could use a router and make ¼" deep pockets on the bottom of the treads! That way you wouldn't have to do anything to the stringers.
This is probably the way I'd go.
Willie T
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
