Tray Ceiling, Need Crown Molding Help?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 05:08 PM   #1
Rewards Points: 89
Question
tray ceiling, need crown molding help??
I have a living room with a ceiling of 8 feet. I installed a tray ceiling due to a renovation. My question is from the bottom of the tray to the top of the ceiling is 11 inches. I want to put rope lighting behind crown molding can someone explain the molding part. Im lost on what size molding. Where to start it, from the bottom of the tray for it to reflex well off the ceiling. Picture of what I have is here, sorry i don't know how to resize
chipraynor is offline   Reply With Quote
Old 10-20-2011, 06:17 PM   #2
Rewards Points: 5,336
Rope lighting is mood lighting, so dropping the molding 2-4 " down from the ceiling would be fine.
As to the size of the molding? What size is the room? How are you energizing the rope lights? An outlet behind the molding?
The molding needs to be ascetically appropriate and functional(to hide the outlet) I'd say a minimum of 3 1/4 to maybe 4 5/8".
Ron
B. Franklin 1759
Old 10-20-2011, 07:32 PM   #3
Rewards Points: 89
The size of the room is 12 wide by 18 deep
I just have a elec. Wire hanging out to a dimmer, going to put in a single socket for the rope lights, I pit it in the middle 6inches down.
Looked online and they have the molding that attaches and comes out 5" from the tray. I'm lost on how to attach the molding, do I do layers, 1 base then crown? Does the crown not need to be AT&T he'd at the top?
Thanks again for the help
Old 10-20-2011, 07:49 PM   #4
You would attach brackets around the room's perimeter. It would be mounted to the wall studs and match the spring angle of the crown molding. You could carve out a recess to drop the lights into and clip them in place.
Ron
B. Franklin 1759
Old 10-20-2011, 08:32 PM   #5
Rewards Points: 282
you also cant legally dim an outlet, which is what it sounds like you want to do.
just FYI.
jcrack_corn is offline   Reply With Quote
painting a room with crown molding net_tech Painting 12 10-24-2011 04:45 PM
How to handle crown molding transition to kitchen cabinets mystic_cobra Carpentry 6 09-15-2011 03:37 PM
Crown molding with Recess's in wall 169stang Carpentry 22 11-02-2010 04:30 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
ceiling tray down from 8' ceiling rtoni Building & Construction 8 08-15-2008 04:07 PM
