Tools Needed?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-01-2014, 12:07 AM   #1
Rewards Points: 874
Tools needed??
What tools/saws do I need to install/cut crown molding? Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 01-01-2014, 04:23 AM   #2
DIY staff
Rewards Points: 7,174
You need a miter saw with a fence tall enough to nest the crown against---a set of crown stops--can be shop made---
Perhaps a coping saw,if you will be coping the inside corners---
A brad or finish gun and compressor--or a hammer and nail set---
Good ruler---and a sharp pencil.
A small bottle of wood glue ---
Old 01-01-2014, 09:31 AM   #3
Rewards Points: 874
Originally Posted by oh'mike
You need a miter saw with a fence tall enough to nest the crown against---a set of crown stops--can be shop made--- Perhaps a coping saw,if you will be coping the inside corners--- A brad or finish gun and compressor--or a hammer and nail set--- Good ruler---and a sharp pencil. A small bottle of wood glue ---
Thanks mike. The " fence" part has me confused. Does that come with the miter saw?
Old 01-01-2014, 09:36 AM   #4
Rewards Points: 142
yes, it is part of the saw. its the part you push the wood up to.
Fix'n it is online now   Reply With Quote
Old 01-01-2014, 09:37 AM   #5
Rewards Points: 142
is your crown going to be stained wood or painted ?
Old 01-01-2014, 09:38 AM   #6
Rewards Points: 874
Will this drive up the price of the miter saw. Can I make something similar? Looking for an inexpensive miter saw. Less than $120
Old 01-01-2014, 09:49 AM   #7
DIY staff
I suggest you get a sample of the crown molding and bring it to the store with you--
Many of the cheap saws have short fences----there are home made jigs that might work ,but as a novice, I suggest you get the right saw and not deal with jigs--
Crown molding is easiest to cut 'nested' against the fence---upside down--in the proper angle---you need to have 'crown stops' so the trim stays in position as you cut----
There are simple home made stops---when the time comes one of us will help with that---
gregzoll (01-01-2014)
Old 01-01-2014, 09:56 AM   #8
Rewards Points: 874
I suggest you get a sample of the crown molding and bring it to the store with you-- Many of the cheap saws have short fences----there are home made jigs that might work ,but as a novice, I suggest you get the right saw and not deal with jigs-- Crown molding is easiest to cut 'nested' against the fence---upside down--in the proper angle---you need to have 'crown stops' so the trim stays in position as you cut---- There are simple home made stops---when the time comes one of us will help with that---
Thanks a lot Mike. HNY
Old 01-01-2014, 01:42 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
A ladder, caulk gun, spackling compound, block of wood, I think Mike already said frail pole, or bump bar, or whoop stick.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (01-01-2014)
Old 01-01-2014, 02:45 PM   #10
Rewards Points: 153
If you're only doing inside corners, you can just use a coping saw. $120 for a compound miter saw is a little inexpensive.
eandjsdad is offline   Reply With Quote
Old 01-01-2014, 03:40 PM   #11
Rewards Points: 874
Yes, I agree.
Old 01-01-2014, 05:57 PM   #12
Rewards Points: 153
If you're willing to learn to cut on the flat, you could probably get by with a Kobalt 7 1/4" sliding compound miter saw. You can also make all these cuts on a tables saw, but that's much less convenient.
You might want to do a little learning before you tackle this. Here's a start:
http://www.finewoodworking.com/how-t...n-molding.aspx
The Following User Says Thank You to eandjsdad For This Useful Post:
Mstrlucky74 (01-01-2014)
Tools for a newlywed beginner mephysteaux General DIY Discussions 9 09-24-2010 11:43 PM
What Tools Are Needed to Clean Air Ducts Yourself? limitdiy HVAC 1 07-27-2010 08:57 PM
What to do with all the shop tools when the shop master passes away ??? JohnFRWhipple General DIY Discussions 8 06-21-2010 08:32 PM
Bathroom Vanity Changout-What Tools Are Needed? jte1130 Tools 2 10-06-2008 02:25 PM
