Tools For Cutting Out Subfloor Against A Wall. - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 06:39 PM   #1
Tools for cutting out subfloor against a wall.
Hey All-
I hate to introduce myself with a question, but I'm pretty certain several people have. I'm redoing my bathroom flooring due to some water damage. I've pulled up the linoleum and have gotten a good look at the area of damage. My question is, the area goes right up to the tub and back wall. I have read several places to "cut out" the sub-floor where it is bad. I'm having difficulty getting a clean cut against those two surfaces (the wall and tub). I've used a circular saw for the open areas and a Rigid Sawsall to get a little more. However, the cuts are at an angle into the subfloor (something I'm not pleased with, and will likely need to correct before laying in the new subfloor. Any ideas on getting a better flush cut against the wall and tub?
Thanks in advance-I'm learning a great deal.
jowiv1 is offline   Reply With Quote
Old 10-30-2008, 06:47 PM   #2
RippySkippy's Avatar
Welcome aboard!
What about using a sharp hand saw...something like this? Do you have access to the joist cavity below the floor? If you get the rotten subfloor out, you can add blocking between the joist from below to provide support where the new and old meet.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-30-2008, 07:12 PM   #3
we did this same type job at work last month, used a dremel tool with blade to cut right along the tub, we did get the attatchment that allows you to extend the cutter away from the tool
DUDE! is offline   Reply With Quote
Old 10-30-2008, 07:49 PM   #4
You need a toe-kick saw.
http://www.harborfreight.com/cpi/cta...emnumber=94626
jerryh3 is offline   Reply With Quote
Old 10-30-2008, 08:45 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by jerryh3 View Post
a toe kick saw...well, that toe kick saw is not adjustable and does not allow you to cut flush with the surface.
Might I suggest a Fein Multimaster or one of the copycat tools (I think Bosch and Milwaukee make them)
Old 10-30-2008, 09:29 PM   #6
That would work too.
Old 10-31-2008, 06:34 AM   #7
Holy Cow
You are all great. Thanks for all of the great tips/tools. I'll likely try out the hand saw idea and move up the ladder should that not work. I'll keep you all posted and have some photos of the finished job. Thanks again. I've been learning a lot and I'll try to keep up online.
Old 10-31-2008, 01:27 PM   #8
Drywall contractor
Rewards Points: 1,070
Bosch is supposed to have it's version out this month (maybe it came out today.......) but haven't been able to find one. The cost is about $100.00 compared to around $400.00 for the Fein from what I've seen. For the occasional user (like myself) the Bosch would be the way to go. Haven't seen/heard of a Milwaukee, will have to research that one.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-31-2008, 11:03 PM   #9
a toe kick saw should work it was made to cut the subfloor or underlayment at the toe kick of base cabinets if the base board is off it will cut very close to the wall I have one and it will work up to 3/4" regards Rob
super carpenter Rob is offline   Reply With Quote
Old 11-01-2008, 10:07 AM   #10
I took another shot at it with the Rigid sawsall, I started the notch with a 1/2 inch drill bit. My plan is to plane it down with either a hand sander or planer to make it square. Unfortunately, after I pulled out the subfloor, I had the pleasure of seeing water marks on the joists. Woohoo, further down the rabit hole for Alice!
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
