Tools - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 10:13 PM   #1
tools
I have many dewalt xrp 18volt tools with nicad batteries. My charger says it will charge nicad and lithium batteries. So my question is.....will lithium ion batteries work in my xrp tools?
erics1971 is offline   Reply With Quote
Old 10-13-2011, 12:39 AM   #2
firehawkmph's Avatar
Rewards Points: 1,822
Eric,
They should. I have one lithium battery and charger that charges lithium and nicads. The lithium battery works fine, but it is slightly smaller and lighter than the nicads. So you just have be more careful with drills and tools that you stand up on their base. They will stand, but easier to knock over.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-13-2011, 07:28 AM   #3
The tool wants 18V, it does not care what makes that voltage. If the battery connections fit, it will work.
The Following User Says Thank You to Just Bill For This Useful Post:
Ron6519 (10-13-2011)
Old 10-14-2011, 10:15 AM   #4
Check with your manufacturer, most newer drills accept NiCad, NiMH, and Lithium. Lithium is much lighter than the other two, and deliver a steadier power curve through discharge, and tend to recharge faster and last longer.
yeag6154 is offline   Reply With Quote
Old 10-15-2011, 07:18 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
it depends on the style of the lith ion battery if its the same stick in style as nicads yes, however dewalt has switched their battery design to the slide in style like makita, bosch and milwaukee.
woodworkbykirk is offline   Reply With Quote
Tools for a newlywed beginner mephysteaux General DIY Discussions 9 09-24-2010 11:43 PM
What to do with all the shop tools when the shop master passes away ??? JohnFRWhipple General DIY Discussions 8 06-21-2010 08:32 PM
need information regarding powered drain cleaning tools Pipe7000 Tools 1 10-18-2009 02:05 PM
Value of used tools Texasguy Building & Construction 6 06-02-2007 12:03 PM
