Tool Selection - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 04:42 PM   #1
Tool selection
I am attempting to cut a curved end on a 4" x 8" plank. My vintage U-shank jig saw won't cut it. (pardon the pun) Blades not long enough. Circular saw makes a mess. Forget hand tools. Might be a good excuse for a reciprocating saw. Would a reciprocating saw do the job. I used a 8" pie plate to make my curve.
gpace1 is offline   Reply With Quote
Old 12-19-2010, 04:49 PM   #2
Cabinet maker
Augie Dog's Avatar
You need a jig saw.
This is just a picture to show the type of saw.
Augie Dog is offline   Reply With Quote
Old 12-19-2010, 05:00 PM   #3
You can get longer blades for these
mrgins is offline   Reply With Quote
Old 12-19-2010, 05:36 PM   #4
Thanks for the replys. I am a little confused though. My old Skilsaw jigsaw has a hard time cutting through 2" stock with a new blade (Bosch U234X) It doesn't stall, it just won't cut well. Real slow.
Old 12-19-2010, 05:38 PM   #5
Cabinet maker
Augie Dog's Avatar
Sorry I miss read the dimensions of your board. I now see that it is 4" thick. That is a different animal.
Here is one way to go;
Make a plywood pattern just a bit smaller than you need. Clamp it to the top of the board and use a router with a guide collar and a couple different lengnths of straight bits. Making several passes with each one til you are within an inch or less of cutting all the way through.
Then switch to a bottom bearing flush trimming bit and flip the board over and use the previous ct as the pattern to finish up. Sand smooth.
Or just get a long blade for a jig saw and use a belt sander to square the cut. The jig saw will cut it but will be way out of square. The router will cut square but you need all the stuff.
I hope this helps, no easy way to do this with minimal tools.
Old 12-19-2010, 05:50 PM   #6
Rewards Points: 1,760
You might call a wood working shop in the area and see what they'll charge to cut it with a bandsaw or similar. Might be worth it.
bob22 is online now   Reply With Quote
Old 12-19-2010, 05:51 PM   #7
Yes, and the board is 10' long. Cumbersome. Will a new Bosch jigsaw do it? I can't get longer u-shank blades for my old Skilsaw. Will the recip saw do better?
Old 12-19-2010, 06:27 PM   #8
Cabinet maker
Augie Dog's Avatar
I took the dog for a walk and changed my mind again on my recommendation.
I would use a skil saw making several passes from both sides working close to my line.
When i felt I did the best I can with that, I would clean up with a belt sander.
Two tools and 10-15 minutes, you are there.
Old 12-19-2010, 06:39 PM   #9
Thanks. I will do that.
Old 12-19-2010, 08:34 PM   #10
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Good advice from Augie
If you were going to do a number of cuts in 4" material I would recommend using a Festool Jigsaw
I have that saw and it is expensive, but it can do more than any other jigsaw especially with those 5" blades.
The model I have is this one:http://www.onlinetoolreviews.com/rev...oolPS300EQ.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-21-2010, 04:41 PM   #11
This is probably the best way seeing as you dont have a bandsaw.
Nucon is offline   Reply With Quote
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 07:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Help on tool selection for leveling concrete slab Wohn Flooring 3 07-11-2010 02:03 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
