Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-30-2009, 08:37 PM   #1
tool or bit that will help clean out hole in chair
I have a chair that needs repaired,the back fell off and i can see that it was held together by a couple of wooden joint pieces.I need to find a good tool that will help me take out the wooden joints and clean the hole completly so i can buy more and put them in the holes.
Thx
ron0805 is offline   Reply With Quote
Old 11-30-2009, 08:59 PM   #2
PHB Construction LLC
Paulie's Avatar
Biscuits or dowels?
Paulie is offline   Reply With Quote
Old 11-30-2009, 09:05 PM   #3
Originally Posted by Paulie View Post
Biscuits or dowels?
biscuits
Old 11-30-2009, 09:09 PM   #4
ArmchairDIY's Avatar
Originally Posted by ron0805 View Post
biscuits
You will need to use a biscuit joiner then. The original biscuits are glued into the slot and cutting them out will be the only method of removal.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself!
ArmchairDIY is offline   Reply With Quote
Old 11-30-2009, 09:12 PM   #5
they are glued in,but there has to be a smaller and handier tool to use for this..its just 2 holes
Old 12-01-2009, 08:18 AM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Hand held Dremel.
Old 12-01-2009, 08:46 AM   #7
the Musigician
DangerMouse's Avatar
I had this problem once, I put a fine, chisel edge on a nut-pick and it worked out well.
It picked out the glue, and the curve chiseled it down to wood again.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Tool to make a hole in bed rail Thurman Tools 10 08-10-2011 01:15 PM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 11:45 PM
