Tongue And Groove Pine Ceiling- Staggering The Pattern. - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2008, 08:23 AM   #1
Tongue and Groove Pine Ceiling- Staggering the Pattern.
I have a room that measures aproximately 12 x 16. It has a vaulted ceiling on to which my wife and I plan on installing tongue and groove pine.
I know I will need to stagger the pattern of boards as I install them, but I'm a little unclear as to how the "pros" do it. Do I simply do a pattern of 8'-8', 4-8-4; or will that look funny? Suggestions?
Randell Tarin is offline   Reply With Quote
Old 04-06-2008, 08:51 AM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Can't you get longer boards? 12' or 16'.
Sir MixAlot is offline   Reply With Quote
Old 04-06-2008, 05:33 PM   #3
I guess I could, but transporting them may be a problem. I'm also doing it by myself.
Old 04-08-2008, 06:33 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Do you plan to leave the butt joints exposed? What is your joist spacing? Can you get 10' boards?
Old 04-08-2008, 10:18 AM   #5
The joist spacing is 16" OC. Yes, I was thinking about leaving the butt joints exposed. However, I checked yesterday and I can get the boards I need in 16' foot lengths AND delivered.
Old 06-14-2008, 11:42 AM   #6
I am looking for 16' T&G for my ceiling as well. Where did you find it? How did your project turn out?
katlaw is offline   Reply With Quote
Old 06-16-2008, 02:45 PM   #7
I'm getting ready to do it this week.
What I plan to do is get 16' t&g and sand and finish it before it goes up. I'm going to rent scaffolding to get me and a helper up high enough without having to go up and down a ladder (old knees, ya know).
I do have a silly question though: does one start at the bottom and work up or at the top and work down?
Old 06-16-2008, 03:28 PM   #8
47_47's Avatar
Rewards Points: 58
Rip the groove off of one board and start at the bottom, tounge side up. Plan your layout so you do not have a sliver at the top. Make sure your pine is properly acclimated to the room. Seal all surfaces and cut ends, otherwise it will cup.
47_47 is offline   Reply With Quote
Old 06-16-2008, 03:31 PM   #9
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
We used 8 footers. We used 4 footer to stager the joints every course on 24" OC scissor trusses. The butts are exposed. We just routered the ends with a 45 degree bit. We started at the bottom and worked up. We ripped the first board at an angle to butt up against the wall. We also pre finished the boards prior to install. They has also bee on site for a few months prior to install. Used 16 ag 2" nails in a Paslode angled gun.
comp1911 is offline   Reply With Quote
Old 06-16-2008, 03:31 PM   #10
Seal ALL surfaces? Even the ones not showing?
Old 06-16-2008, 03:33 PM   #11
I hate it when that happens.
Old 06-17-2008, 05:57 AM   #12
I haven't started my project yet, either. I am still trying to find 16' t&g; I am hoping some of the local lumberyards will have it b/c HD & Lowe's only carry up to 12' lengths. I did find some good articles on how to install. The one on the HGTV site even has pics.
Old 06-17-2008, 06:32 AM   #13
Comp1911 I like the look of your ceiling but just how did you account for the lights.Did you put the T&G up first and then cut it out or cut it and then install it around the lights
clasact is offline   Reply With Quote
Old 06-17-2008, 07:14 AM   #14
47_47's Avatar
Rewards Points: 58
Yes, all surfaces. The unsealed surfaces will absorb moisture from the humidity in the room and the boards may cup. You do not have to stain the back side, just seal it and seal all cut ends prior to installing.
The T&G should be already on site. I use a moisture meter and compare it's reading with other pine in the room. Without a meter, I recommend a minimum of one week to acclimate, then sand, stain and seal. If the boards come in with a higher moisture content they are slightly wider and your joint will open up when they reach equilibrium. If they come in lower, the boards will be slightly narrow and the boards will expand.
Old 06-17-2008, 07:23 AM   #15
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
We just made the cuts as we installed the boards. Just fit up, trace a line and cut the section out with a jig saw.
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 12:14 PM
Headache with 2 x 6 tongue and groove millie Flooring 9 04-04-2012 08:00 PM
Tongue and groove miami vice 25 Flooring 8 04-04-2012 06:35 PM
Painting tongue and groove bahamaspete Painting 5 03-30-2008 09:16 AM
