Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-05-2011, 05:57 AM   #1
tongue and groove ceiling
I brought a house that was built in the 70's. It has tongue and grove ceilings which are beautiful. But, since I have lived here for the last 3 years I notice a yellow dust continuously on my furniture and hard wood flooring. The ceiling appears to never have been sealed. I did paint our bedroom ceiling which also get this yellow dust on the furniture. Could the dust be coming from the ceiling? Are the boards expanding and contracting and releasing dust? If so what can I do about it?
robbet10 is offline   Reply With Quote
Old 11-05-2011, 06:28 AM   #2
If there is a room above the tongue and groove ceiling, than walking up there may cause the dust. You should seal the tongue and groove with a varnish or lacquer sealer. This will help seal the wood and prevent the dust. Be sure to pay close attention to the groove part of the ceiling. If there is not a room above the ceiling, it could be an issue in the attic.
Kader516 is offline   Reply With Quote
Old 11-05-2011, 06:34 AM   #3
There is no attic. The roofing is above that. Do I have to chalk the groves?
Old 11-05-2011, 06:59 AM   #4
I would hit the tongue and groove lightly to see if the dust is coming from the wood. If it is, than the sealer would help. Do not caulk the joints or you will spend you life caulking as the wood expands and contracts. If the roof is above the dust may be coming from the sheathing material that the tongue and groove is amounted to. If you can't solve the problem with a sealer, I would use spar varnish if it is stained, than you may have to lightly caulk and paint it. Try hitting the wood first to be sure it is the ceiling first. It may not be coming from there.
Old 11-05-2011, 11:18 AM   #5
Stuck in the 70's
Blondesense's Avatar
Do you have your windows open much, or do you notice is more in certain times of year? We have issues with pollen seasonally.
Old 11-06-2011, 12:38 PM   #6
Boston Fan, get over it
Toofarfromfenwa's Avatar
Let's try this again.
I bet your ceilings look like this.
http://i63.photobucket.com/albums/h1...del2011004.jpg
(ETA: Picture were HUGE. Fixed link)
I had the same problem. Never did figure out what it was.
I fixed that problem.
http://i63.photobucket.com/albums/h1...del2011023.jpg
http://i63.photobucket.com/albums/h1...del2011022.jpg
http://i63.photobucket.com/albums/h1...del2011021.jpg
http://i63.photobucket.com/albums/h1...del2011020.jpg
Put insulation up there, ran my electrical, and put T&G Southern Yellow Pine up over top. Added to my R-Value, and still kept the T&G look of wood that I love.
My house was built in 1955, and it was VERY common then.
Good luck!!
Toofarfromfenwa is offline   Reply With Quote
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 01:14 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 11:40 AM
tongue and groove ceiling heathm3 Off Topic 1 04-06-2010 05:36 PM
Tongue and groove patio ceiling nailers Dave DB Carpentry 7 08-05-2009 01:46 AM
Heavy Dust & Tongue & Groove Ceiling Fix bobricci Flooring 4 11-08-2008 09:47 PM
