Tongue/groove Boards - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 10:49 AM   #1
tongue/groove boards
I want to install ponderosa pine tounge/grove on the walls/cellings. 1/2 in thick boards. What type of nail gun and nails do you recomened. and where should the nails be placed?
Ron J is offline   Reply With Quote
Old 12-04-2010, 10:52 AM   #2
As for type of nails I am not sure to be honest but screw type nails like you use on wood flooring would be a good start.
Nail the boards through the tongs so the fasteners are hidden and you wont need to fill them.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 12-04-2010, 12:25 PM   #3
jlhaslip's Avatar
Rewards Points: 2,188
2" 18 ga brads work okay. Shoot 2 at each rafter/stud/joist.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (12-04-2010)
Old 12-04-2010, 02:25 PM   #4
are you going over existing drywall or bare studs/ceiling joists. You can get ringshank pneumatic nails for the ceiling that would hold better. 2" if on bare wood, 2 1/2 over drywall. make sure you're hitting the joists. I assume you're going horizontal on the walls otherwise you need blocking between the studs or 1x4 nailed perpendicular across the face of them
mrgins is offline   Reply With Quote
Old 12-04-2010, 03:07 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
I agree with jl, nails any larger will more than likely split the tongue as the T&G is only 1/2 inch thick.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-06-2010, 01:32 PM   #6
what are the widths of the boards?
oldtoyotaboy is offline   Reply With Quote
Original Fascia boards need to be replaced brickhaus Roofing/Siding 3 08-25-2010 10:10 AM
Gate post ledger boards Klawman Building & Construction 5 04-14-2010 01:22 AM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 11:09 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 06:59 PM
