Toggle Bolt Through Stud? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 10:09 PM   #16
Rewards Points: 5,336
Screw the mount is with the screws supplied and be done with it.
Ron
B. Franklin 1759
Old 09-25-2011, 07:41 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
i would never trust a toggle bolt to hold anything heavy, and it compltely boggles my mind why you would drill completely through a stud to install a toggle. the spring and the washer on the toggle bolt will more than likely snap under the tension create when tightening hte bolt. you will have far better success by using a lag bolt into the stud or cutting out a section of the drywall and putting a peice of 3/4" plywood that is slightly larger than the hole in behind, screw through the drywall to hold the plywood with several screws then refasten the removed peice of drywall back... from there you can fasten the tv bracket to the plywood with a heavy gauge screw
woodworkbykirk is offline   Reply With Quote
Toggle / anchor bolt question masada Drywall & Plaster 3 07-06-2011 01:39 PM
toggle bolt stuck in stud pilcher Drywall & Plaster 1 06-28-2010 09:14 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
Best Toggle Bolt? kevinyates General DIY Discussions 1 08-01-2009 09:02 PM
Bolt Next to Stud Clutchcargo Building & Construction 9 11-26-2007 01:19 PM
