Tips Needed: Exterior Door With Alarm Sensor - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 02:09 AM   #1
Rewards Points: 150
Tips Needed: Exterior Door with Alarm Sensor
I'm wanting to replace an exterior door that has the sensor that makes the alarm chime when the door opens. I can see the sensor is installed at the top of the door.
My questions are...
How do I disconnect the sensor when removing the door? Will it unplug from the wires? (I haven't removed the trim to get a good look at it yet.)
I assume there is a magnet on the top of the door slab. Do I just remove it off the old door and glue it on to the new door?
Any tips on how to deal with this sensor would be great.
ConstantChange is offline   Reply With Quote
Old 09-06-2010, 09:48 PM   #2
Rewards Points: 5,336
One of the components will have two wires attached. Once you expose them, disconnect the wires from the terminals.
Ron
Old 09-06-2010, 10:40 PM   #3
Rewards Points: 150
Thanks Ron. I changed out the door tonight. Like you said...two wires. I had to cut them and reconnect them once the new door was in place.
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Cooper Motion Sensor Help needed please scoops Electrical 3 02-23-2012 11:39 PM
Extreme novice warning: Plaster tips needed. Poser Drywall & Plaster 9 03-19-2010 03:12 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 10:30 PM
