Tips Needed: Exterior Door with Alarm Sensor
I'm wanting to replace an exterior door that has the sensor that makes the alarm chime when the door opens. I can see the sensor is installed at the top of the door.
My questions are... How do I disconnect the sensor when removing the door? Will it unplug from the wires? (I haven't removed the trim to get a good look at it yet.) I assume there is a magnet on the top of the door slab. Do I just remove it off the old door and glue it on to the new door? Any tips on how to deal with this sensor would be great. |
One of the components will have two wires attached. Once you expose them, disconnect the wires from the terminals.
Ron |
Thanks Ron. I changed out the door tonight. Like you said...two wires. I had to cut them and reconnect them once the new door was in place.
| All times are GMT -4. The time now is 12:28 PM. |
