Tips Needed To Cut Stud Close To Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 06:57 AM   #1
Smile
Tips needed to cut stud close to wall
i have removed the middle of 2 studs in a non load bearing wall so that i can recess a bathroom medicine cabinet. currently on the right side of the photo is another stud behind the drywall. currently the hole is about an inch off center to the sink below. if there any reason why i couldn't remove this stud as well as the 2 i already cut off? what would be the best way to remove it being in the corner?
The other side of the stud to be removed is a kitchen pantry.
montpsycho is offline   Reply With Quote
Old 01-11-2011, 07:15 AM   #2
Rewards Points: 6,652
As for the hidden stud, have you tried a dry fit with the cabinet to see if it will fit now? If still needing a little room as is, you can shave a little more off of the Gypsum. Why not just shave off of the left side? Why do you have to do the right side? Think outside of the box.
Old 01-11-2011, 07:54 AM   #3
Rewards Points: 152
Personally, I would not want to remove one of the corner studs, so looking at it from another angle, assuming you were to widen the opening to the left, and understanding that it may not be exactly what you had in mind, couldn't you pinch the the sink or vanity to the left as well, in order to line up the sink and cabinet? Also, maybe I am looking at it wrong, but it appears that you may need some manner of blocking to prevent the drywall on the opposite wall from being pushed in.
Old 01-11-2011, 08:09 AM   #4
Rewards Points: 5,336
If you remove the stud, the corners will lose their nailing surfaces. Try moving it back an inch or 2.
The whole stud is exposed so you can cut all the fasteners. Then just tap it back and refasten it.
I don't know why this stud is an issue and the sheetrock isn't as they're both in the same plane.
Ron
Old 01-11-2011, 08:32 AM   #5
Rewards Points: 152
Not sure, but I think that the OP is referring to a the stud that we cannot see, to the right of the opening; not the one that we can see, in the middle of the opening.
Old 01-11-2011, 12:43 PM   #6
The one in the middle would be for the opposite wall on the other side. But I must be blind, because there is no stud in the opening to help secure the Gypsum to the left of that sleeping stud. Looks to me, more of a DIY job on the drywall, and walls, since the spacing is off. Tape measure must have been broken when they built that place, or two bubba's working from opposite ends.
Old 01-11-2011, 12:57 PM   #7
Rewards Points: 152
I saw that as well, and just assumed that they put the stud on the wrong side of the line, and didn't do anything to correct it when they put the wall on the other side in place. That's the reason that I mentioned that there needs to be something to keep the drywall on the opposite wall from being pushed back.
Old 01-11-2011, 01:00 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Looks to me that the 2 studs that the OP cut off were there to secure the drywall on the back of the wall we see. Since he only cut out 18" or so I do not think there is a problem. If there is a extra 1/2" in depth available, I would cover that area with a piece of plywood and screw through from the opposite side.
To cut the unseen stud on the right, I would use an oscillating saw.
Cheap version $30 from Harbor Freight.
http://www.harborfreight.com/multifu...ool-67256.html
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
montpsycho (01-11-2011)
Old 01-11-2011, 05:21 PM   #9
yes there is nothing to prevent the other side of the wall being pushed in, other than the fact that the wall is behind the fridge. the other half on right side of the stud you can see is the back of the kitchen pantry. the full stud running vertically in the picture is the divider of the wall where the kitchen pantry starts. - not sure why it's done that way, but i was hoping that the 25 inches i cut out would not be a problem concerning the problem of the walls pushing in on the other side.
I really like the oscillating saw idea, my concern is i need to cut 1 & 1/4 inches off the stud. leaving only a 1/4" of stud to help support the medicine cabinet in place. i had thought of making a hole in the kitchen pantry and screw in a 2nd stud on the existing stud. so then i will have a whole stud plus 1/4" of the stud i cut in the wall to hold the medicine cabinet in place. does this sound good?
why are jobs always bigger than they seem?
Old 01-11-2011, 05:45 PM   #10
DIY staff
Rewards Points: 7,174
You should try bidding a remodeling project some time--These little surprises often cost a paycheck----
Gary in WA (01-11-2011)
Old 01-11-2011, 05:52 PM   #11
the Musigician
DangerMouse's Avatar
Don't get me started.....
DM
Old 01-11-2011, 06:00 PM   #12
It is the nature of the beast. Guaranteed, that you will take six more trips to the store after you make the big purchase to start the job, and always find out that you end up either renting, purchasing or borrowing the extra tools needed to get the job done.
As for hacking lumber off of the 2x4, as pointed out before, why not take off of the left.
Old 01-11-2011, 06:52 PM   #13
While your building this, cut the exposed 2x4s back 1 1/2" above and below the opening so that you can lay a flat 2x4 from full stud to full stud horizontally, otherwise your medicine cabinet will be flopping in the breeze. If you need the full 3 1/2" depth of the opening, use sheet metal screwed flat to the end wall stud shown to hold the drywall in the corner in the kitchen. Just be aware of the wire that's showing. Can that be rerouted?
mrgins is offline   Reply With Quote
Old 01-11-2011, 07:17 PM   #14
that was the in the original plan. i will run a new wire from the box up to the light that will go around the cabinet.
once again for all, it is very unsightly to have a cabinet not centered over the sink.
Old 01-11-2011, 08:03 PM   #15
The move the sink over a bit.
Tags
remove , stud
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 10:31 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
