Tips On Cutting Stringers? - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 10:18 AM   #31
Old School
Willie T's Avatar
Well, maybe my screen is showing something different, but this is what I see......
The one with the red arrow, showing a possible SPLIT point, is what you seem to have.
The closer one is how it should be.
Willie T
Old 06-14-2013, 10:20 AM   #32
Rewards Points: 150
The one with the red arrow, showing a possoble SPLIT point, is what you seem to have.
Look at the "closer one". It is the exact same cut. In both cases you have full bearing, only the back one sits on solid wood, the closer one sits on plywood. You've also drawn the back one as a ledger that is side-nailed into the board next to it instead of bearing on the floor itself.. but that is less important.
Nice that you made that image so fast tho.
SquishyBall is offline   Reply With Quote
Old 06-14-2013, 11:44 AM   #33
Old School
Willie T's Avatar
OK. I finally get it. The stringers actually sit down into a deep hole cut into the floor? And there is wood under that?
Never seen that, but seems like a pretty good idea if your hole is dead-on.
Willie T
Old 06-14-2013, 11:57 AM   #34
Old School
Willie T's Avatar
In effect, this is what you have, right? Pretty doggone clever!
Willie T
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Tips for installing crown molding as a on man job? gmhut Carpentry 3 05-14-2009 07:21 PM
Cutting in Bubbagump Painting 21 11-04-2008 10:23 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
