Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-15-2010, 01:21 PM   #1
Timberlok or lag bolts on PT wood posts?
I'm getting ready to bolt some 4x4 PT posts onto my deck for the rails. Should I go with the Timberlok wood screws, or run a lag screw all the way through?
The posts are dried, and the deck is dried as well. But there is a chance I may have to do a few posts using brand new (wet) 4x4 posts.
spaceman spif is offline   Reply With Quote
Old 09-15-2010, 11:15 PM   #2
jlhaslip's Avatar
Bolts, not lags.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 09-15-2010, 11:58 PM   #3
Whoop...yep, meant to say bolt all the way through. Anyone have any preference/experience using Timberlock screws vs. lag bolts?
Old 09-16-2010, 08:29 AM   #4
You should drill through the posts and use bolts with washers and nuts on support posts and railings railings
daveb1 is offline   Reply With Quote
Old 09-16-2010, 01:24 PM   #5
Moderator
No screws! Through bolts only. Figures 24, 25, 26: http://www.lancova.com/deckinfo.pdf
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
spaceman spif (09-16-2010)
Old 09-16-2010, 03:16 PM   #6
Gary
Excellent info in that pdf file! Answers pretty much all my questions!
(I sure am glad I notched only two of my 4x4 posts!)
Old 09-17-2010, 12:48 PM   #7
You'll want to be sure to get bolts approved for use with PT lumber.
How strong are fence posts? Suggestions? Thoughts? johnluk Building & Construction 8 06-01-2009 08:37 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
