-   -   tiling shower wall (http://www.diychatroom.com/f14/tiling-shower-wall-39970/)
beth5542 03-09-2009 03:23 PM
tiling shower wall
The walls on the side of our shower are the lath and plaster we have taken the old tile off and don't know if we should put up the backer board or try to repair the walls with plaster what is the best way? We are giong back with tile
Bob Mariani 03-09-2009 03:35 PM
remove the plaster, install 1/2 cement backer board, tape seams , waterproof coating , then tile
beth5542 03-09-2009 03:48 PM
Do you have any suggestions on how to remove the plaster
Termite 03-09-2009 04:18 PM
You don't want that plaster in a wet area. It would be best to remove it. You can cut the edges very carefully with a keyhole saw to define the edges and then wreck it with a hammer and a pry bar. Remove the lath and plaster.
Shim the studs as necessary with wood strips to apply 1/2" backerboard flush with the face of the adjoining plaster. Use backerboard screws. Then tape and thinset the backerboard seams, and waterproof it with RedGuard or Kerdi. Then hang tile with thinset mixed from a bag (pre-mixed isn't great for showers).
The Tile Council of North America has some pretty good installation practices on their website.
Ron6519 03-09-2009 04:21 PM
It sounds like this is not in the shower. The tile application you describe is an odd one. Older homes with tile were done in a mud job. The only plaster was above the tile. The fact that you got the tile off without destroying the plaster entirely is amazing. Sounds like it was put on by a homeowner after the initial installation.
Definitely remove the plaster and lath. If it's wood lath, take the plaster off first by hammering the walls from the bottom up. This will break the keys and it will fall to the floor. After all the plaster is all cleaned up, remove the wood lath.
These walls will not be plumb. The framing might not be even close to being on the same plane. You might have to shim the wall to get it close to plumb. Install the concrete board to just below the tile level if you're not going all the way to the ceiling. Use a mold free sheet good product for the rest of the way up. Tape all seams
Ron
