Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-15-2007, 01:02 PM   #1
Tile installation question
I am in the early stages of planning a master bath renovation and I am planning on building an open "free form" shower stall. I have selected the tile for the walls of the shower (okay, my wife did ) and it is very large... 24x24 tiles. The online brochure for the tile shows it installed where there is hardly any noticeable grout line at all, almost as if they installed the tiles flush to each other. However, the picture in the brochure is obviously a space designed just for looks, and probably isn't truly functional.
So my question is, what are "rules" about grout width? Is it purely done based on the look you want? Is there a minimum grout width based on the tile material and size of the individual tiles (I would think there would be, due to expansion possibilities). I do not see any info in this particular tile catalog about recommended grout line width.....
pjpjpjpj is offline   Reply With Quote
Old 10-17-2007, 09:37 PM   #2
I'd also like to know, free bump...
Bacardi 151 is offline   Reply With Quote
Old 10-17-2007, 10:00 PM   #3
I think it's purely asthetics, with some consideration for the grout. Below 1/8 wide (if my memory serves me) you use unsanded grout, and presumably there is some minimum spacing that allows you to squish grout into the crack with a float. I think 1/16" would be plenty of space for that, and on a 24" tile, that's going to basically be invisible.
A more important consideration here, is that your walls are perfectly dead FLAT! A tile that large is very unforgiving with wall irregularities.
NateHanson is offline   Reply With Quote
Old 10-17-2007, 11:50 PM   #4
Agreed.. grout lines are purely what you want them to be. 1/16 would be your best bet if you dont want to show any grout lines... use a grout color that blends in well and it will be invisible. and yes UNSANDED grout! Sanded is for floors!
ajan246 is offline   Reply With Quote
Old 09-21-2008, 12:29 AM   #5
My experience working with tile is that you would want a 1/4" grout joint on a tile that large. It gives you a little wiggle room with installation. Also you need to consider how smooth and straight the edges of the tile are. Is this a rustic tile with distressed edges? Is this a travertine tile with crisp eased edges?
The tiles I see bumped up close with little to no grout joint are marble and travertine. The rest have a grout joint.
My vote goes for 1/4" grout joint.
jonblack
jonblack is offline   Reply With Quote
Old 09-21-2008, 12:29 AM   #6
Please post a link to the online brochure you mentioned.
jonblack
Old 09-21-2008, 11:10 AM   #7
Building codes guy, Mod
thekctermite's Avatar
jonblack, this thread is almost a year old, so I'll be surprised if you get a response.
thekctermite is offline   Reply With Quote
Old 09-21-2008, 12:29 PM   #8
Yep, you are right. I didn't even look at the date. I was just going down the list of subjects and thought this one looked interesting.
jonblack
More On This Topic
Depending on the material used for the backerboard, it will change shape over time. Your tile and countertops will begin to show wear and could move out of place. To avoid this, you should leave room for the expansion. An eighth-inch is a good size for... Read More »
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Hi this is Jon and in this clip we'll be grouting. If we take a look at the base of our door on the inside we have a nicely laid tile that's grouted, however when we did install the door we had to chip away some of the grout so that our new door would... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment I am going to be showing you how to do a dry run with your tile to make sure the layout is working. As you can see we have snapped our lines and what you can do if... Read More »
How to Seal Tile
How to Seal Tile by Expert Village
I’m Lee; I have a degree in architecture and about ten years experience in the construction field, and have been installing designer countertops today. After you have gotten the tile down to the countertop, you want to go ahead and seal it. A lot... Read More »
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Ceramic Tile Backsplash Installation DK75 General Discussion 4 11-01-2006 08:56 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
