Tighten Loose Nowel Post On Inside Staircase - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 09:22 PM   #1
Tighten Loose Newel Post On Inside House Staircase
My house is about 5 years old.
The stair case to the upstairs has several newel post. Some of them are pretty loose. (the stair case is basic builder grade)
I would like to know how to tighten them. The post are sitting on the stair tread not to the floor joist.
There is a knock-out circle but I can not see inside the whole once I take the knock-out..out. I am pretty good at small repairs. Thanks, Cathy H
I have attached a pic of one of the post with the knock-outs
csh49 is offline   Reply With Quote
Old 03-01-2010, 10:25 PM   #2
jlhaslip's Avatar
Rewards Points: 390
There are probably screws of some sort or Lag bolts inside the holes under the plugs at the base of the newel posts.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 03-01-2010, 10:29 PM   #3
Thanks for the note. I can't see what is in the hole with a flash light. Any way to tell if its screws or lag bolts?
Old 03-12-2010, 05:55 PM   #4
just pop the plug and remove the screws they are about 3 1/2'' long replace them with longer ones 5'' long enough where you can reach the2x4 make sure you drive'em in well so you can get a tighter fit and you should be good to go i hope that will help
01stairguy is offline   Reply With Quote
Newel post repair for dummies Zarack Carpentry 17 06-20-2011 05:43 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Repairing loose newell post?? Rod53 Building & Construction 2 09-07-2009 06:17 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
