Threshold Or Quarter Round First? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 11:20 PM   #1
threshold or quarter round first?
Hey guys I am finishing the kitchen Reno and the kitchen tile floor is about a quarter inch higher than the hardwoods.
So I need some sort of threshold piece, I think the sell them at home depot.
Should I lay the baseboards, 1/4 round then set the threshold piece in?
Or should I lay the baseboards, THEN set the threshold piece in and then lay the 1/4 on top?
The second way I would have to cut angles in the 1/4 round, I'm not sure the first way would make sense....
sannitig is offline   Reply With Quote
Old 10-29-2012, 12:01 AM   #2
pictures would help to understand clearly
Old 10-29-2012, 12:02 AM   #3
Rewards Points: 13,270
Can you post a picture?
Old 10-29-2012, 11:26 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
make a threshhold out of hardwood thats a steep angle that runs up to the tile
woodworkbykirk is offline   Reply With Quote
Old 10-29-2012, 12:25 PM   #5
Yup thanks but which order do I place the 1/4 round and the threshold down?
Old 10-29-2012, 12:38 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
Install the threshold and then the 1/4 round or shoe mold. One side of the shoe or 1/4 round will be higher as you know, if you want to get creative, rip the difference of the floor heights off the bottom of the molding, install and cut the threshold to fit the 1/4 round.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-29-2012, 12:42 PM   #7
funfool's Avatar
Rewards Points: 534
Is there trim around the entryway? Baseboard would butt the trim and not matter which goes first.
Question is, how will you end the baseboard, or will it just wrap around and continue into next room?
funfool is offline   Reply With Quote
Old 10-29-2012, 12:57 PM   #8
to answer both questions at once I'm probably going to use a plinth that wraps 2 inches on each side of the wall.
As for the shoe I was thinking cut it at an angle going over the threshold
Old 10-29-2012, 01:00 PM   #9
there is no trim around the entry and I was planning on ripping the plinth to go over the tiles....
I'm starting to wonder if I even need to shoe around the plinth.... placing a shoe would complicate things more because the finished side already has a different shoe than I'm planning to use on the Reno side.... I would probably have to rip up the shoe on the finish side
Old 10-29-2012, 01:30 PM   #10
funfool's Avatar
Rewards Points: 534
Good chance adding the 1/4 round would look to busy.
If I understand correctly, would be the plinth, threshold, then look at the 1/4 round and see if you want it.
If the baseboard butts and stops at the plinth, may want to end the 1/4 there also.
Old carpenter here, I had to google plinth just to see what it was.
Never heard of it before, we learn something new everyday.
Old 10-29-2012, 01:34 PM   #11
Bombastic Idiot
notmrjohn's Avatar
Flooring store has transition pieces for just such cases, that'd be your "threshold." Or make your own as kirk said. Wide side should butt against tile. If tile edge is not as straight as you wanted it, you may have to use thicker strip that over laps it.
Just to make sure, you know base shoe and quarter round are different things with different profiles?
Generally speaking you start at bottom and work your way up, so transition strip first. Cut molding and trim to fit over it.
Without seeing exactly what you got there, I'd say plinth or corner block idea is good. Trying to match dissimilar profiles at joints can be tricky. Bit easier on inside corner, cope wider or taller to fit over smaller. A pic from you would explain situation, a pic from me would explain my coping with junction.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-29-2012, 04:09 PM   #12
more often than not buying premade thresholds dont work for the situation.. as they arent hte correct measurement.. also when there is new hardwood going in its better to use scraps or left over wood so you have something that matches what the floor is
Old 10-29-2012, 04:24 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I hope I didn't mislead someone to think I was calling 1/4 round shoe mold because it isn't the same thing but some people will confuse them for the same thing. Is what you are trying to do like this or something else. Notice the base and 1/4 round (not shoe mold here) is ripped down to make the transition and not make that the focal point.
Jim
Old 10-30-2012, 10:50 AM   #14
AHH, SPANS!!!
Rewards Points: 1,166
for that situation I sometimes use the threshold laid flat to the hardwoods and notch the 1/4" out of the underside to allow it to go over the higher floor elevation(tile), it does not need to lap over much. a little construction adhesive during install to tighten up the voids and it is good to go.
a pre made threshold will slide through the tablesaw to take out the 1/4" just as easily as a threshold made on site.
hand drive is offline   Reply With Quote
Old 10-30-2012, 11:08 AM   #15
I think I posted some pictures already. I will be placing the transition piece last (someguys say place first and some place last). This way I have time to figure what exactly I want to do here
It's in a doorway (with no casing or trim, just drywall). I have decided that the shoe will not look good on the plinth portion (thanks for the tip).
***Important***
I was unable find plinth as I thought plinth was sold in linear feet, not just a 4" x 8" tall block or what have you like the local home depot, so I think I may have to make my own plinth to place in the doorway and 3" around each side of wall.
I have purchased an 8' length of 3.5" x 3/4" mdf whiteboard and an 8' length of 4.5" x 3/4" mdf white trim/baseboaseboard. I am thinking of stacking them and laminte with PL to make my 8" x 3/4" "plinth". That way I can cut however many inches wide the doorway is
Only propblem I can think of is what to fill the joined part with to make it fully flush and unnoticeable.
And is MDF good enough or should I be using something like poplar instead for both pieces??
if need pics I can send.
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 10:20 AM
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 07:00 PM
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
quarter round + door frame= headache fenceman Flooring 3 02-15-2009 03:28 PM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 07:08 AM
