Think You Can Teach Me How To Build This ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 12:17 AM   #1
Think you can teach me how to build this ?
sup guys, i saw this photo somewhere on fb i think.. and for months i've been thinking of wanting it, but i think i can build this if im given some right advice.. any help is appreciated, i live in a small city so availability might be an issue but hopefully not..
saad.khan is offline   Reply With Quote
Old 07-03-2012, 02:35 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
I think I remember that from the movie 'Army of Darkness" with Bruce Campbell.
Nasty looking.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 07-03-2012, 06:43 AM   #3
A bunch of plastic or wood pegs, screwed from the back side of a thick piece of plastic, piece of cake. Lexan would be best, but expensive, I would say at least 1/4" thick. Drill and countersink holes for pegs.
The Following User Says Thank You to Just Bill For This Useful Post:
saad.khan (07-03-2012)
Old 07-03-2012, 07:15 AM   #4
DIY staff
Rewards Points: 7,174
Do check your home owners insurance --that looks like a hazard to the health.
Old 07-03-2012, 07:50 AM   #5
Old School
Willie T's Avatar
Tacky! That is a divorce just waiting to happen.
Willie T
Old 07-03-2012, 10:57 AM   #6
luckily unmarried
Old 07-03-2012, 11:03 AM   #7
Renovations contractor
Bonzai's Avatar
Find a local freak show and ask for the guy that lies on a bed of nails ... That's what this looks like.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-03-2012, 05:24 PM   #8
You can get this material for cabinets, bathroom uses, or window replacements. A simple drill will penetrate plastic, and then you need to set in a screws or hooks for your design. You could hang it by putting screws through it, through some sort of spacer (bits of pipe or wood dowels or something) into the studs in the wall.
You could replicate the exact hooks by using Sculpy, a modeling clay that can be baked in an oven. It can make either pottery like items or even has more flexible types (I have some hair ties made from it). An art store would have that.
-Crissa
CKentavr is offline   Reply With Quote
Old 07-03-2012, 10:10 PM   #9
Haverhill Trade 1965
Can't tell if those pegs are hard or not but I am sure you can find something like it in a craft shop. Looks like it could be one of the 101 uses for a dead cat though.
Duckweather is offline   Reply With Quote
Old 07-04-2012, 12:22 AM   #10
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here was the original designer!
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-05-2012, 10:51 PM   #11
Originally Posted by kevinbrown966 View Post
This is not a good thing to build as the lower hooks can hit anybody's head or some other part of the body even while walking nearby it. You should take this frame and just build the upper lining of the design so that it is only used for hanging things like clothes or hats on them.
Did he say it came from facebook or face hook. It looks pretty easy to build. Just screw pegs, from behind, to sheets of plastic. It looks strangely similar to a ring toss game mounted vertically.
Old 07-08-2012, 11:36 AM   #12
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
You blokes are just too funny............
I have to agree that to me it is "Butt Fuggly"..........but a challenge.
This is not as easy as it may appear to build.
For idea's on the pegs go to http://www.bearwood.com/PEGS.HTML
This will save a lot of time if something suits your fancy.
Using a "Shaker Peg" as a hook , these can be pre-painted.
Installing these pegs at an angle will dictate an angled shoulder which should be avoided as it is tough to do, so find one that has a straight shank. If an angle is desired, use a peg with a nob on the end and install it at 90 deg which is simpler. These can be glued into the hole,
The plexiglass is relatively expensive and you will need it to be at least 1/2" thick to hold any weight without buckling. I would suggest using a MDF of 3/4" thick so that you can bore a hole for the peg with a box bit.
A plexiglass or lucite panel of say 1/8" can be picked up at home depot a lot cheaper and added as an overlay.
If you do decide to install the pegs at an angle, you will need to utilize a drill press and set the bed to the angle you need. Take time to position the holes as you will notice the slightest deficit.
We wanna see a photo of this when it's done
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Planning to build First Spec Home, Need Advice ahb2012 General DIY Discussions 53 05-27-2013 07:30 AM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 11:51 PM
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General DIY Discussions 10 12-07-2011 01:10 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 05:39 PM
