Think This Would Be Strong Enough To Hold Lead Acid Batteries? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 09:49 PM   #16
Rewards Points: 6,652
Originally Posted by djlandkpl View Post
You can infer all you want. The first sentence states his intent.
And as I stated before, you need to go back and read the Mod named Red Squirrel's previous posts.
Old 07-16-2013, 09:54 PM   #17
chitownken's Avatar
Rewards Points: 510
No point in arguing. Sorry I asked. Won't help the Squirrel get the shelves built.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
kwikfishron (07-17-2013)
Old 07-16-2013, 11:12 PM   #18
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I may possibly add some home circuits to it too like the TV and office but it will mostly be for the servers.
Current setup:
Kinda messy looking, so the shelves will make it better, and the inveter-charger will go in the beige rack, which I'll dedicate for power and lab stuff while the open rack is production stuff (has better cooling, while closed rack will provide protection for power stuff).
The rack will go where the current batteries are, leaving room so a couple hvac ducts can pass between it to go in the crawlspace where my hvac control system will be. Will be setup as a hot/cold aisle setup. A bit overkill for a home server room, what why not. In winter it will just vent throughout the house, but should the hydrogen levels go high it will switch to outdoor air immediately. Need to find some motorized dampers that don't cost $900 though... but that's a whole other topic. :P
So long story short, my existing design looks pretty solid then? Maybe replace the 2x6 planks with plywood instead?
Originally Posted by chitownken View Post
So just curious, why are you building a server room? Going to start web hosting out of your basement? Development work?
Mostly hobby stuff, but lot of it is production, like file storage, firewall, hvac control, media server etc... Lot of development stuff too. I'd love to do web hosting but I don't have the bandwidth for it. Everything else would be a piece of cake otherwise. I'd make the entire basement the server room, and get some AC units and standby generator and I'd be set. But with 1mb upload, not happening. :P
Old 07-16-2013, 11:13 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,980
I want to build a battery bank for my server room,
Could be for the servers....could also be for the house....could be for both...
3/4" plywood is plenty strong....I would put get some plastic trays to lay the batteries on.
As long as the charger is good....there should not be an excess of hydrogen gas expelled.
ddawg16 is online now   Reply With Quote
Old 07-16-2013, 11:29 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 834
I would look into unistrut. I use it for pipe racks and stands in mechanical rooms.
It's an adults rector set
Old 07-16-2013, 11:33 PM   #21
Wire Chewer
Rewards Points: 132
Trying to avoid having to buy anything new. I already spent lot of money on this project lol.
Unistrut looks very interesting though... But still the trouble of finding a place I can buy, probably have to order etc... shipping would be a killer. Looks like some of the stuff used at work (telco CO) actually for cable vault, ceiling cable tray holders etc.
Old 07-17-2013, 06:21 AM   #22
DIY staff
Rewards Points: 7,174
The only weak spot in your design is missing cross bracing on the back---a plywood back or cross bracing will give you a stable box/rack.
Old 07-17-2013, 08:14 AM   #23
You know, I was thinking, what about old Bread tray racks. You can modify the angle iron and reuse for your project, to hold the batteries as they sit in the wood rack.
Old 07-17-2013, 01:28 PM   #24
Wire Chewer
Rewards Points: 132
I was thinking that too, I may put some bracing for the bottom shelf on the back and front. Since the sides will have plywood I wont need any bracing there. Will ensure it keeps square both sideways and forward. Wont put any batteries on the bottom "shelf" as the bracing will be in the way, but I will use it to store stuff like the hydrometer, gloves, safety glasses etc.
The bread racks could be interesting too.
Drywall patch strong enough to hold an anchor? kevind Drywall & Plaster 4 02-08-2013 08:51 AM
Replacing lead toilet drain and flange klondiker Plumbing 7 02-17-2012 09:53 PM
Something to hold 2 hoses together? konsole Electrical 6 05-13-2011 09:38 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Muratic acid on aluminum clad windows jarrodbowles General DIY Discussions 25 05-01-2009 04:42 PM
