Thin Spindles - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 10:09 AM   #1
Rewards Points: 27
Thin Spindles
I have a loose banister section that needs securing. The lower section that has five vertical spindles in a circle is loose. The spindles are secured at the bottom with small screws but I don't feel like this is enough support because of how thin they are. Would I have to remove the carpet to re-support these or is there a way of making them solid without having to dismantle everything and re-build?
RomanDesign is offline   Reply With Quote
Old 12-10-2011, 03:38 PM   #2
recently retired
Rewards Points: 280
There isn't a Newell post and it appears that the balusters are toe nailed in so there needs to be some work done if you want it to be more solid.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
BigJim (12-10-2011)
Old 12-10-2011, 04:50 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So...the whole assembly moves?
Old 12-10-2011, 05:12 PM   #4
DIY staff
Rewards Points: 7,174
That needs a newll post--
Old 12-10-2011, 10:38 PM   #5
Rewards Points: 5,336
You need to remove the rail assembly and the rug off the tread and as already stated, install a newell post. If you want, now is the time to upgrade the balusters.
Ron
B. Franklin 1759
Old 12-11-2011, 08:06 AM   #6
Rewards Points: 27
Yes the whole assembly moves. It's actually a neighbour friend of mine. They were told by someone else that it was an easy fix, so they are expecting me to do that "easy fix" -- I had a feeling it would be a little less easy than they anticipated
Old 12-11-2011, 08:12 AM   #7
Rewards Points: 27
The other railing (longer section) is built the exact same way at the bottom and it feels pretty solid -- probably because it is a continuous piece as opposed to a small section. If I replace one side with a Newell post -- I would assume Id have to do both -- this is a bit beyond my skill set and beyond what they are willing to do right now.
Old 12-11-2011, 08:28 AM   #8
DIY staff
You are smart to step out of the picture----securing a newell post correctly into an existing stair is a real project----
Old 12-11-2011, 08:36 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
That could be your out, just tell them it is just a little out of range of your skill set, that is not a simple fix.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-12-2011, 07:41 PM   #10
Stairguy
Millertyme's Avatar
Rewards Points: 508
When it gets fixed, the carpet should be ripped out of there. There is probably nice oak under that carpet. I dont understand why anyone would want that carpeted anyway. The proper way to fix would be to carefully remove the rail from the balusters, add an actual newel in there with perhaps a 3004 newel fastener from Lj Smith ( they are very easy to install), drill a new hole under the volute to accept the newel and reattach the rail. Perhaps not a diy job.
Millertyme is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
thin set removal from hardwood floor Dhays Flooring 1 10-26-2010 04:03 PM
Thin set vs mastic/glue for ceramic tile ph3iron Flooring 6 02-17-2009 08:56 AM
Railing Spindles avalon Carpentry 6 08-26-2007 04:41 PM
