Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-01-2007, 08:01 PM   #1
Thickness of workbench tabletop?
I scored a killer deal on some 3/4" oak plywood today ($4 for each 2'x4' sheet!). Would one of these be enough for a simple workbench tabletop, or should I double-up and make it 1.5" thick?
I need to secure my 5" vise to it as well, so would 3/4" be strong enough?
Thanks!
curls00 is offline   Reply With Quote
Old 09-01-2007, 08:41 PM   #2
Remodeler
MinConst's Avatar
3/4" for a bench is fine if you build a 2x4 frame on 16" centers. Where the vise is going add a second piece under the top for more meat to attach to.
I just built a wood working bench using 3/4" for the top and fastened 2x4s to the framing where my bench dogs will go through. Works like a charm.
I've built many work benches out of 3/4" never had an issue. Just reinforce for heavy tools and your vice.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-01-2007, 08:52 PM   #3
Sounds like a plan -- what I was going to do anyhow unless told differently.
Thanks!
Old 09-04-2007, 09:58 AM   #4
Workbench is completed and is darn sturdy!
Next question -- should I coat the worksurface in polyurethane for durability, or, leave the oak plywood untreated? The things I see in this are:
Treated = durable, extra-hard, won't mar/scratch/chip/splinter.
Untreated = less slippery (a good thing), but can chip/splinter, dentable.
Opinions?
Old 09-04-2007, 10:12 AM   #5
I use 1/4" CG ply on my workbench surface and radial arm saw surface. I counter sink screws in for easy removal when it gets too damaged.
BTW, my workbench top is laminated 2x3's on end. Total surface is 2'x7'.
Here's the top after some hand planing before the 1/4 ply get's installed.
Jeekinz is offline   Reply With Quote
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 11:48 PM
Glass shower enclosure- What thickness should I use? showerneeded Remodeling 2 06-05-2007 08:28 AM
Driveway thickness??? mdlbldrmatt135 Building & Construction 3 12-01-2006 08:56 AM
Wall thickness RickT Carpentry 2 10-16-2006 10:23 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
