Which Thickness OSB For A Shed - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 03:21 PM   #1
Rewards Points: 1,062
Question
which thickness OSB for a shed roof
i posted 7/16 OSB on the walls of my 11x9 shed, now i am ready to make the roof. was wondering if i should use the same OSB or some other thickness?
thanks
Old 01-27-2011, 05:13 PM   #2
Rewards Points: 5,336
thanks
I 'm not a real fan of a material that's reverts back to little pieces of wood when it gets wet, so I'd opt for a different material.
What are you covering this with?
Ron
Old 01-27-2011, 06:18 PM   #3
Registered User
Rewards Points: 5,256
http://publicecodes.citation.com/ico...9_8_sec003.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
amakarevic (01-28-2011)
Old 01-28-2011, 01:02 AM   #4
housewrap and then cedar siding for the walls, roof haven't decided yet probably just regular shingle roof, i guess...
thanks
Old 01-28-2011, 08:26 AM   #5
A Little Of Everything
Rewards Points: 1,364
thanks
7/16 OSB really isn't adequate for your roof, even if you're running rafters on 16" centers. You might get by with 7/16 plywood, but even that would be iffy.
I put 5/8 OSB on the roof of the 8x12 shed I built this summer (16" centered rafters). It worked fine. It's a shed. And hey, it was on sale.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 01-28-2011, 09:06 AM   #6
Carpenter
dtsman's Avatar
OSB is fine all the way around. Good enough for houses, good enough for a shed. The OSB thickness will be based on the rafter spacing. 7/16 will be fine for 16" on center, and 5/8 for 24" on center rafters.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
The Following User Says Thank You to dtsman For This Useful Post:
Old 01-28-2011, 09:41 AM   #7
^ True.
I guess I'd say that there is "minimum code" and then there is acceptable. I know that in some cases, 3/8 OSB is code, provided you have clips. I just don't get that at all...
Also, here in the upper Midwest, we tend to build heavier because of snow loads.
But, as you mentioned, it's a shed.
Old 01-28-2011, 10:23 PM   #8
Rewards Points: 150
OSB fine
When you say "shed" I think of a 8' X 12' building to store your lawnmower and rake and it does not require a building permit or need to meet any building code. If this is the case then 7/16 should do fine, with 3/8 you might get a bit of an uneven appearance, but it is a shed. If by a "shed" you mean a 16' X 24' accessory storage building that requires a building permit and needs to meet code then use 1/2" rated sheathing, that can be 15/32" plywood or OSB, just make sure it is considered "rated sheathing". If it requires a building permit you should make sure you build it to code whether or not you are getting a building permit as sooner or later (as when you sell your home) you will need to get a building permit and certificate.
TheCamper is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 01:16 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
