Is There A Rule Of Thumb? Balusters - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-12-2009, 09:48 AM   #1
is there a rule of thumb? balusters
I got the spacing thing figured out pretty good, but what about the distance a baluster should be from the stair tread/nose? should it be the same as the distance from the newel post to the first baluster?
thanks
Laurie
mrmac204 is offline   Reply With Quote
Old 05-12-2009, 11:07 AM   #2
47_47's Avatar
Rewards Points: 50
For open risers, place the down side of a baluster so that is flush with the face of the riser. Every tread will have a baluster in this spot. Divide the run into equal parts and that is the spacing for the others.
You are looking for uniformity and consistency of the balusters and the treads.
47_47 is offline   Reply With Quote
Old 05-12-2009, 05:06 PM   #3
Old School
Willie T's Avatar
This may simplify it if your treads are 10" from nose to nose as many are. If not, using 10" like this shows you some easy division to apply to your own measurements.
(All these measurements are "center-to-center" of the balusters... so your baluster size doesn't effect this layout.)
And "No", they don't necessarily have to be right on the edge like I've shown it. Some are, many aren't.
Willie T
Old 05-12-2009, 05:14 PM   #4
Thanks guys! I can work with that - I will try to post a pic of what I've done so far. Its not finishied yet so I can change the baluster placement.
Laurie.
Old 05-12-2009, 06:30 PM   #5
Rewards Points: 1,578
I'm not sure I'm on track with the question but isn't there code on spacing between balusters for child safety purposes? Might this affect the overall spacing of the components being installed?
bob22 is offline   Reply With Quote
Old 05-12-2009, 07:52 PM   #6
Registered User
Rewards Points: 5,482
Click on the purple one:
http://www.stairways.org/codes_standards.htm
Be safe, G
Old 05-12-2009, 09:03 PM   #7
I guess this one:
http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
Old 05-13-2009, 09:03 AM   #8
Old School
Willie T's Avatar
The setup on the right is the maximum you can go with this layout, using 1.5" wide balusters. It just does leave you 4" between... and if your baulsters are smaller than 1.5", or narrow down anywhere, this layout won't work...... you'll have to put three balusters per tread, spaced much closer together.
Stay aware of things like this.
Willie T
Old 05-13-2009, 12:24 PM   #9
Love for Construction
<*(((><'s Avatar
4" or less distance between balusters is required by code. An inspector was always checking our distances, when I worked as a superintendent.
<*(((>< is offline   Reply With Quote
Old 05-13-2009, 03:41 PM   #10
Old School
Willie T's Avatar
That's why I said what I said. Both these drawings show that. The measurements you see are "center-to-center".... meeting code if using full 1.5" balusters.
Willie T
Old 05-13-2009, 04:07 PM   #11
<*(((><'s Avatar
Never said you didn't say that. And I fully understood the drawings.
*EDIT* I just realized I probably hit the quote button rather then reply. If so, sorry my fault.
Old 05-13-2009, 04:47 PM   #12
Old School
Willie T's Avatar
No, my fault, I should have said: "It just does leave you the code required 4" between...".
Willie T
rule of thumb for tamping backfill elementx440 Remodeling 5 05-30-2013 11:46 PM
Rule of thumb...knobs or pulls and placement? Kelly R. Remodeling 4 02-11-2009 04:50 PM
Rule of Thumb for attaching to concrete timclaason Building & Construction 6 02-09-2009 07:36 AM
Is there a rule of Thumb Here? 1parkpointer Electrical 8 12-08-2008 09:30 AM
Static Pressure: Rule of Thumb? rjordan392 HVAC 4 06-06-2008 12:55 PM
