Is There A Difference? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 07:49 PM   #1
Is there a difference?
So I'm trying to build a quality bench for my tools and equipment. Is there a difference between the expensive plywood versus your normal standard plywood?
deathvomit28 is offline   Reply With Quote
Old 04-20-2012, 08:25 PM   #2
Rewards Points: 12,856
http://www.insidewoodworking.com/plywood-grades.html
Old 04-21-2012, 08:03 AM   #3
CrossWorks's Avatar
Rewards Points: 150
I would use 3/4" Baltic Birch plywood, simply because of the numerous layers of ply. 7 layers I believe.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-21-2012, 09:06 AM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
Birch ply is a good choice. It is usually pretty flat and makes a nice finish product. It's about 45 a sheet though. CDx is good if you are not worried about the appearance. Mdf is a good choice for the top because it is flat and smooth, but I would only use it on the top. Mdo is also a great choice but is a little pricy. It is very water resistant though, if that means anything. And the there is ac which is good but for the price you might as well spring for the birch
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
goosebarry (04-21-2012)
Old 04-22-2012, 11:18 AM   #5
Thanks y'all! Really helpful
Old 05-04-2012, 07:32 PM   #6
Like your username!
mrgins is offline   Reply With Quote
Old 05-04-2012, 10:07 PM   #7
Too Short? Cut it Again!
It kind of depends on what you are using your workbench for.
Mine used to have, among other things, grinders attached to it for basic sharpening of lawnmower blades and chisels. It was thick oak and maple. The high heat shavings of metal would near destroy any birch veneered piece of plywood?
My drawing table top, used more as a dining table than a drawing table sits on a MOMA base. It is birch ply combo. It has been functioning perfectly in both capacities for decades now.
Difference in hardwood floors BryantS Flooring 0 10-02-2010 02:17 PM
What is difference between expensive faucets and medium $? Pontiacgirl Plumbing 4 01-19-2010 10:07 AM
Does difference in vinyl siding thickness matter greatly? moneymgmt Building & Construction 4 11-19-2009 02:44 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Is a big price difference normal? chevyguy1973 Roofing/Siding 5 02-08-2006 11:06 PM
