Termite Shield - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 06:50 PM   #1
termite shield
Dumb question, is the order of install for a termite shield:
foundation>>>sill sealer>>>termite shield>>>PT plate
or
foundation>>>termite shield>>>sill sealer>>>PT plate
I've been reading and seen it both ways. Personally I think it's supposed to be the first version but I'd like someone to confirm.
Also, what are people using for material for the shield itself? Galv., copper, something else?
RolandOG is offline   Reply With Quote
Old 07-19-2008, 02:55 AM   #2
747
registered
747's Avatar
Rewards Points: 534
or
I'm 99 percent sure its the second one.
747 is offline   Reply With Quote
Old 07-19-2008, 07:14 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
The proper sequence is as follows
1) Foundation sill sealer ( helps fill small gaps in foundation between the sill and the concrete to cut down on wind infiltration)
2) termite shield, Termite shields protect the sills from insects getting into the wood sill, second defense. The sills are treated with Alkaline Copper and Quaternary Ammonium compounds The only product to my knowledge that is approved for the use with ACQ is a copper lined polyethylene membrane
3) Wood ACQ sill Plates
BOB
Old 07-20-2008, 03:40 PM   #4
Not surprising I get opposing answers. As I said, that's what I've been reading. My gut tells me it's sill sealer then termite shield so that's what I'm going with. Thanks.
Old 07-20-2008, 03:50 PM   #5
buletbob's Avatar
Its the correct way, Its there to cut down on drafts.
Old 02-19-2010, 05:49 PM   #6
Next question regarding the installation of the termite shield is which side goes down. Copper or the other side. Heard it doesnt matter but have always put copper down because termites will work there way up to wood sill plate.
scottob is offline   Reply With Quote
Old 02-19-2010, 07:34 PM   #7
Framing Contractor
or
Foundation, sill sealer and PT plate with no termite shield. Is this code in your area? I've only used it a couple times in the past 20 years because it was on the plans. Since sill sealer came out no more termite shield.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-25-2010, 10:31 AM   #8
Dan - Green Builder
Materials are just as important as the sequence. The sill requires a sealer which acts as a gasket to block moisture, air and bugs from entering through the small gaps between the top of the foundation wall and the sill plate. However using a product like Blu Wood for your sill plate has a lifetime transferrable warranty against termites and fungal growth. It also limits moisture absorption and transfer. You don't need a termite shield if you build it right with the right products.
nHabit Builders is offline   Reply With Quote
Ice and Water Shield hansemx1 Roofing/Siding 19 11-07-2012 09:32 PM
How do I replace termite damaged top plate under trusses on a load bearing wall? durangorob Carpentry 7 07-25-2011 07:45 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Snow and Ice Shield Over Rolled Roof? Basic_Homeowner Roofing/Siding 17 04-29-2007 10:17 AM
