Temp. Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 05:18 PM   #1
MDT
Temp. Wall
i need to build a temporary wall in the garage that will stay up for the next 11 months and i will take it down i would like to know what will the best way to do this and if this is possible
MDT is offline   Reply With Quote
Old 07-21-2009, 05:30 PM   #2
Cement floor?
Dividing a 2 car garage or ?
Are there ceiling joists/sheetrock currently?
Pic of the area?
Garages will usually have a slope towards the door
So probably best to build the wall in place
If ceiling joists/sheetrock I'd install a top plate in place
Then cut a bottom plate, then cut each stud as needed.
I'd make each long slightly longer and wedge them in place
What is the wall going to be used for?
Will both ends be able to be secured to an exisiting wall?
Old 07-21-2009, 05:42 PM   #3
MDT
Temp Wall
Yes there are existing walls with drywall on it; it will be used for a temporary art studio for my son and maybe a play area for my younger kids
Old 07-21-2009, 06:02 PM   #4
Ah...I forgot - how much distance between the 2 walls where it can be tied in?
Sheetrock on both sides or on the side where the kids are?
If the wall is pretty long then it should be secured into the cement
Only having sheetrock on one side (at 1st) woudl allow you to test the wall & see how strong it is
Using a single top/bottom plate will make the wall stronger
Old 07-25-2009, 10:25 AM   #5
Drywall contractor
Rewards Points: 1,070
Easiest way would be to frame it out of metal studs. Removal is far easier than wood framing. A few concrete pins or "tapcon" screws in the bottom track and a few 1-5/8" screws through the ceiling into the joists will hold fine......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-25-2009, 01:15 PM   #6
Jay123's Avatar
Never worked with metal studs so bjb might be spot on. As for myself, I would either tapcon the sole plate in first or use a Ramset (powdered actuated) or similar (my choice).
Build your wall with studs 2 - 2 1/4" short of the ceiling (yes, just toe-nail into sole plate from both sides, they'll hang on if nailed correctly. Nail your far left and far right stud to existing walls (make sure to plumb them).
Cut your top plate, nail to far left and right studs...then toe nail the rest of your studs into the top plate (plumb, of of course).
If you really want to re-use the stuff a year later, you can use screws to attach the studs, but I don't have enough patience for that.
After demo a year from now, patch your existing walls and concrete floor.
If you're fairly handy you can probably accomplish this in 2 - 4 hours after getting set up. I won't say how long it would take me, as it would only lead to chaos...
Jay123 is offline   Reply With Quote
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 01:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
