Technique For Keeping The Insulation In The Ceiling During Wall Construction? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 11:32 AM   #1
Technique for keeping the insulation in the ceiling during wall construction?
Afternoon,
I'm working on splitting a large, finished, second floor room into two parts. As I get ready to frame the partition wall I have stumbled across a dilemma.
I have to cut a strip of the ceiling drywall out in order to snug up against the ceiling joists, but as soon as I make the cut, the spray cellulose insulation is going to come pouring through the hole!
Any techniques to keep the insulation at bay while I work to put this wall up?
Thanks,
Steve
shaffer911 is offline   Reply With Quote
Old 08-15-2010, 12:02 PM   #2
Rewards Points: 5,336
Leave the drywall in place and just screw the top plate into the ceiling joists. This is just a partition wall.
Ron
Old 08-17-2010, 11:24 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
If you are careful when you cut, and keep the vapor barrier intact, it should be able to hold up the insulation. It's hard to cut without damaging it though. An exacto knife or maybe a multi tool will make it easier.
Sauna Wall construction help Katherine Building & Construction 5 10-05-2016 05:42 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
ceiling insulation question christy123 Roofing/Siding 15 12-18-2008 12:22 AM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
V shaped wall construction brosnt1 Building & Construction 3 02-08-2006 02:00 PM
