Technique- Holding Compass - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 07:50 AM   #1
Rewards Points: 492
technique- holding compass
as i've posted about before, i am trying to scribe a piece of molding so it fits snug against vinyl siding, as i finish my porch project.
what is the proper way of holding a compass when scribing against a wall?
or like this?
or does it not matter?
I've been trying to get this right, even purchasing a better compass, an accuscribe pro. the $2 compass I had kept collapsing. here is my most recent work trying to create a cardboard template:
large view
top, zoomed
middle
bottom
thanks for your help!
joetab24 is offline   Reply With Quote
Old 08-20-2010, 08:41 AM   #2
Old School
Willie T's Avatar
First of all, are the surfaces of your boards straight, or are they "cupped" (bowed inward)?
Secondly, are they evenly spaced?
And third, is the entire height of the wall a flat, straight line when you lay a straightedge across all the lower tips of the boards, or does the whole wall sway or bulge?
Good photos, by the way.
Franšois Duc de La Rochefoucauld
Willie T
Old 08-20-2010, 08:44 AM   #3
jlhaslip's Avatar
Rewards Points: 2,866
http://www.leevalley.com/en/wood/pag...936,50298&ap=1
have a look at that tool
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
nap (08-21-2010)
Old 08-20-2010, 04:51 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
when I scribe like that i use the cheap ones with a small wing nut, The trick is to bend the metal tip away from the pencil at about a 60 degree angle and hold perpendicular to wall
Millertyme is offline   Reply With Quote
Old 08-21-2010, 08:29 PM   #5
Rewards Points: 492
best i could do...looks good
looks clean. will probably paint.
campers and holding tanks... ugabulldog General DIY Discussions 19 03-03-2011 11:04 AM
Faux Finish technique BarcelonaGuy Painting 0 07-03-2010 06:59 PM
PVC recepticle box tabs not holding cable epeterson777 Electrical 8 02-07-2009 09:00 AM
How to remove a technique I did to my kithen walls ekolp Painting 5 12-31-2008 04:55 PM
