Teak And Cutting Boards - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 12:18 PM   #1
Teak and cutting boards
When making a cutting board with end grain cutting surface, what glue/adhesive should be used. because TEAK surface is a bit more oily? will titebond hold or is there a food grade/non toxic epoxy?
pjsmithres is offline   Reply With Quote
Old 07-11-2012, 01:28 PM   #2
joed's Avatar
Rewards Points: 11,980
You need to remove the oil first by cleaning with a solvent like turpentine or acetone. Then usually an epoxy type glue is used. I don't know if normal wood glue will hold.
Old 07-11-2012, 04:55 PM   #3
epoxy
I think that normally. epoxy is toxic and would not be acceptable.
acetone leaves a residue. Lawyers thinner evaporated enough but will regular titebond lll hold real well enough glued on the long grain in a block style board.
Old 07-11-2012, 05:11 PM   #4
the Musigician
DangerMouse's Avatar
Yes, I used it on mine and it's held up perfectly for years.
ONLY use MINERAL OIL after cleaning!
DM
