-   -   Teak and cutting boards (http://www.diychatroom.com/f14/teak-cutting-boards-149920/)
pjsmithres 07-11-2012 12:18 PM
When making a cutting board with end grain cutting surface, what glue/adhesive should be used. because TEAK surface is a bit more oily? will titebond hold or is there a food grade/non toxic epoxy?
joed 07-11-2012 01:28 PM
You need to remove the oil first by cleaning with a solvent like turpentine or acetone. Then usually an epoxy type glue is used. I don't know if normal wood glue will hold.
pjsmithres 07-11-2012 04:55 PM
epoxy
I think that normally. epoxy is toxic and would not be acceptable.
acetone leaves a residue. Lawyers thinner evaporated enough but will regular titebond lll hold real well enough glued on the long grain in a block style board.
DangerMouse 07-11-2012 05:11 PM
Yes, I used it on mine and it's held up perfectly for years. :)
ONLY use MINERAL OIL after cleaning!
DM
