Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-13-2009, 09:46 PM   #1
Tapering and cutting door casing
**UPDATE** After further research and conversing, it looks like the Bosch 4100-09 may solve all my casing install problems
New door installed next to wall. I need to cut the width of the casing 1/2" to fit flush against wall and hinges. Also need to taper the width casing about 1/4" to fit flush for the length of the adjacent wall. This is my first time installing casing.
Handsaw was effective for the rip cut but very slow. I have a Dremel 300 series with router table attachment, I've tried the plywood cutting and sanding bits but it was not able to cut the casing perfectly straight (the bit "wobbled" ever so slightly when pushed against). I also tried marking the cut line and sanding it down on my "work sharp" tool sharpener with 80 grit but again poor results were produced. So after all this hassle I figured I'm probably not doing something right.
From my research, it sounds like a table saw would be easiest to do the rip cut. Could it also be used for the tapering and how would it be set up to cut at the specific taper? I do not currently have a table saw however but may now be in the market for one if it is needed. I'm renovating my entire house so perhaps it can come in handy for other projects.
I'll also be doing an entire floor worth of window and baseboard trim. After my recent experiences with my dremel routing table I don't have the confidence in it to deliver professional trim cutting results. Would you recommend that I obtain a real router in order to cut the beveled edges to fit trim at corners?
destroyer427 is offline   Reply With Quote
Old 09-13-2009, 10:32 PM   #2
You would use a miter saw to cut the corner connections. A miter saw with a bevel feature will help.
I've never used a router to trim out a room with molding, though the tool is very useful if you're making your own moldings.
Ron
Old 09-15-2009, 05:05 AM   #3
Tool Geek
PaliBob's Avatar
destroyer,
I have the Bosch TS and also the Festool TS 55 track saw.
For taper cuts the Festool is far superior because the taper is set by laying the guide rail on the work piece. The saw will cut exactly to the line even with bevel cuts.
I have a tapering jig for the Bosch TS but would not attempt to use it to cut a taper now that i have the Festool.
http://www.tools-plus.com/festool-56...term=FES561174
Disclaimer
& Stay Safe
.....Bob
Old 09-17-2009, 03:18 PM   #4
Household Handyman
destroyer427--I looked at your post and the first thought I had was: Does he feel that he wants a table saw because he's doing this project, or does he really need a table saw because he may have quite a bit of use for one later? Just a suggestion to you: IF you have access to a millwork shop in your area. Can you take the pieces you need cut to them, along with good drawings and descriptions of your cuts and pay them to do these? It will cost for sure, but not the price of a table saw. I actually have a cabinet shop in my area which will do the work for me that I cannot handle with my equipment. Just a thought, Good Luck, David
More On This Topic
Hi, my name is Kevin and on behalf of Expert Village, I'm going to show you to route the ends flush on this box that we've built here. So as before, we've left this in just very slightly proud of this end so that we can come look at the router and trim... Read More »
How to Use a Router Table
How to Use a Router Table by Expert Village
Hi I'm Kevin and I am with expertvillage.com and I am going to talk to you a little about router tables. With a router there is many jobs you can do, hand held, but if you mount a router to a table, your are really able to do a lot of things you can't do... Read More »
Hi, I'm Jon on behalf of Expert Village. In this video clip we'll be finishing our trim for our top. When we glued on our trim for our top. We left just a little bit of a lip on that trim so now we need to come back and smooth that down. For this I'm... Read More »
Ok, the next step in our bedroom project is to actually paint the walls, finally. I've got our paint ready. We're going to go with a flat on the walls and then the trim will be in the semi-gloss. Its quite a color as you can see. I'm going to use a... Read More »
Now in this clip we're going to make a matching cut to our first taper cut. So when you see a tapered leg, you usually will have the two sides tapered and the inside will be straight. This gives a it allows the leg to be plenty strong but have a slender... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
