-   -   Tape & Float Drywall Price (http://www.diychatroom.com/f14/tape-float-drywall-price-1763/)
Shipwash 01-29-2006 11:57 PM
How do I figure how much to pay someone to tape and float my drywall that is already on the walls and ceiling?
jproffer 01-30-2006 01:20 AM
Probably more than you would have paid them to hang, tape and mud it. Problem is, if YOU hang it and ask them to finish it, they don't know what they're getting into. You could have bad joints, offsets, butt joints over studs instead of floated...I'm not saying you do have, but they just don't know. If THEY hang it though, it will be done with the finishing foremost in their mind because, well, that's what they get to do tomorrow, and they want to do it as fast as possible and still have a good finished product.
But to answer your question...how do you figure how much to pay them....well..whatever amount is on the bill of course. It's not up to you to "figure out" what they should be paid, they'll do that and let you know by way of an estimate.
gkmotion 02-03-2006 10:44 AM
As for the pricing, I always get a minimum of three quotes to establish pricing, then try to find out about the reliability of the low bidder. Often it turns out the middle price is a safe choice.
Having just finished hanging drywall for the first time in my home office, I was curious as to why not have butt joints on studs? None of the info I got online mentioned floating them, and they were a pain in the rear. Does floating them make them easier to finish?
ERIK2173 02-03-2006 12:04 PM
I had the same question, I always thought you should have the butt joints over studs for support. Do you do this just for cut joints or for factory edges too? I know it is alway a pain to finish the edges if I screw the board too close to the edge, I guess floating the edges would get rid of thet problem.
jproffer 02-04-2006 12:43 AM
Butt joints should be floated to make for easier finishing. I have hit the ONE stud that was twisted just a little, or out of line by just a little, one too many times and it is a ROYAL PITA. If the stud is twisted, one half of the joint will be higher than the other. If the stud is straight but out of line, the pieces align BUT they approach the stud at a slight angle, which makes them hard to feather out smooth.
As far as supporting the joint: When I say floated I don't mean just hanging out there in the middle of nowhere..at least not alone. A floated joint is backed by a 4 or 5 inch strip of plywood (which, BTW, extends beyond the top edge to the peice above it), and that plywood floats in the stud cavity and (by the rule of "least resistance") it will go where it's most "comfortable"... I.E.-straight in line with the studs on either side.
gdgndrg 03-27-2008 09:23 AM
help on pricing
AtlanticWBConst. 03-27-2008 11:11 AM
Originally Posted by gdgndrg (Post 111278)
help on pricing
Help on your post.
?huh?:blink:
gdgndrg 03-27-2008 12:01 PM
drywall
Originally Posted by AtlanticWBConst. (Post 111302)
Help on your post.
?huh?:blink:
i would like to know what it would cost to hang only, tape only, mud and sand only, 1100 sq ft. the framing is ready to be hung, celing is allready done, walls only.
glenn
jogr 03-27-2008 12:07 PM
No one can tell you guys what someone else is going to charge you on a job we can't see. Call your local drywall guys and ask them for a bid.
gdgndrg 03-27-2008 12:18 PM
drywal
This is not rocket science, there is nothing to do except hang, tape, mud and sand. 1100 square ft. i am not asking for a definite price, i just want to get an ideal of the ball park what to expect????????
Sftail2 03-27-2008 12:27 PM
Around here its about $20.00 per sheet of sheetrock hung for tape & texture. Maybe a little more if you have rounded corners and arches. To hang, tape & texture around $42.00 to $50.00 a sheet.
jogr 03-27-2008 12:37 PM
Picking up a phone to call a drywall guy ain't rocket science either. There are huge regional differences, job differences and business practice differences that will affect what your guy will charge you.
I'm trying to help you, pick up the darn phone and call some local drywall guys. If you have the framing ready already you need to be lining up the drywall work right now anyway.
Double A 03-27-2008 12:45 PM
Expect a price somewhere between a new TV and good used truck. You might ask if there is a discount for impatience, and a keen ability to discern the difference between remodel construction and applied physics.
gdgndrg 03-27-2008 01:27 PM
drywall
Thank you very much, you have been most helpful, more than i can say for some on here. You have a wonderful day.
glenn
AtlanticWBConst. 03-27-2008 01:32 PM
Just realize that the price given to you was regional. For all you know, that could be Canadian Dollars.
I have to run out, otherwise I'd offer some more information to help you. Feel free to PM me, if you want. (there are many factors that will affect drywall pricing)
